Thread Tools |
| 06-03-2026, 08:58 PM | #1 |
Dark Sider
164
Rep 1,790
Drives: 2008 Space Gray Z4MC
E86 rear hatch loose. Lot of lower catch bracket movement
Are these supposed to be tight or loose? Bottom catch bracket for hatch. My catch latch has a ton of up and down,basically all around play and torx bolts seem tight. This allows me to move the hatch 1/4”-1/2” inch when closed.
I could adjust bump stops but then hatch seem to high for body line. Anyone have this issue or could you hatch owners check to see if yours is tight or are they built with some “play” in them? Searched and searched and can’t find a solution. Thanks guys.
Space Grey M Coupe-No Nav-Euro headers-Severn MAF-Based Custom Tune-RPI Scoop-Gruppe M CAI-TMS underpulley kit-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-TC Kline Koni’s with TC RSM’s-Zeck CDV delete- |
| 06-04-2026, 06:15 AM | #3 |
Dark Sider
164
Rep 1,790
Thank you. I will have to figure this out. Nuts seem as tight as can go.
| 06-04-2026, 12:25 PM | #5 |
Dark Sider
164
Rep 1,790
| 06-04-2026, 03:38 PM | #6 |
![]() 295
Rep 224
Drives: 08 Z4 M Coupe
The latch on your hatch and the striker on the body should not have any play when fully tightened. You should use the striker and latch to set the height of the hatch when it's closed. A dry erase marker or grease pen to mark the screw positions is your friend here. Then adjust the bump stops so they are making enough pressure.
The bump stops will be in a good range if you can easily close the hatch but still get a solid "thud" feeling and sound. If you get a loud "pop" when you hit the trunk release on the key fob, back off on the pressure.
| 06-04-2026, 07:13 PM | #7 |
Dark Sider
164
Rep 1,790
Thank you both! Shimmed and adjusted bumpers. Perfect now. Guess 18 years and 46,000 miles will loosen things up a bit
Finnegan787.50 |
| Bookmarks |
| Thread Tools | |
