01-24-2020, 09:59 AM | #2 |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
Didn't bmw make the block cast iron for its strength? I wonder if this will hold up.
JimBob0047269.50 |
01-24-2020, 10:03 AM | #3 |
Rep 382
Residentj3553121.50 pyshin110.50 |
01-24-2020, 11:16 AM | #4 |
Rep 3,004
Wowie -
Advertised as "extreme weight savings"....any idea how much? It is possible to adapt a flat plane crankshaft to this app? Or do flat plane crankshafts only work on 4 cylinder applications? The firing order would conceivably change w/a flat plane, correct? If yes, the camshafts would need to be re-engineered to open valves at different intervals, correct?
Racerbruce
Residentj3553121.50 |
01-24-2020, 03:56 PM | #5 |
Rep 218
Drives: 2008 BMW Z4M Roadster
Aluminum has come a long way but an S54 platform needs some serious overhauls to take advantage of the insane horsepower you can make out of that billet block vs our cast iron. It would mostly be useful for the weight savings.
I'd love to know how much weight it sheds.
2008 E85 ///MZ4 Roadster - Sapphire Metallic Black / Imola Red Int.
IG: Jessed.alvarado Mods: ProFlex E85 Flexfuel kit, Eventuri Carbon Intake w/ RPI scoop, Megan Headers, Custom Axle-back exhaust, KW V3 Coilovers, Stoptech ST40 BBK, Poly FCABs, APEX PS-7s, Diode Dynamics Headlights, CF Trunk Spoiler, Sideskirts & Diffuser. |
01-24-2020, 05:57 PM | #6 | |
Rep 165
Residentj3553121.50 wdb4732.00 |
01-25-2020, 12:04 PM | #7 |
704
I'd love to know the weight savings too, although the N52 S54 comparison is probably a good ballpark.
It's a cool idea. But even more pricey when you add in all the costs on top of the 14k initial layout. I'd guess you're looking at another 10k for the engine build, additional parts req'd and install. |
01-25-2020, 11:13 PM | #8 |
Rep 700
LS Swap Time!
I can think of endless better ways to spend that much $$$ rather than on a billet block. But, I guess if someone will buy it, they will make it. I wonder how many they actually sell.
JimBob0047269.50 |
01-27-2020, 11:40 AM | #9 |
Rep 484
Interesting question is will this block still qualify as a BMW motor for sanctioning bodies like BMW Club Racing? If not, LS would be far better bang for the buck...
01-27-2020, 05:53 PM | #10 | ||
Rep 775
07-11-2020, 10:12 AM | #11 | |
#buildnotbought
10859
Rep 4,893
So for that you're also counting (this is not a complete list): - larger front and rear brakes -dual back exhaust box (complete exhaust in itself is larger thus heavier) -bigger differential, bigger CV joints -oil cooling system Looking at the quoted individual weights of blocks by BMW, I estimate that the difference in weight between engine blocks is about 50lbs, 60lbs tops. BMW quotes that the s54 block weighs 122lbs, and an n52 or m54 block weighs about 77/75lbs (n52 block is virtually equally heavy, it's only part magnesium and is of split design in contrast to the m54). A billet block can be made a little bit lighter. On the other hand, if you want to reduce an already stripped racecar another 60lbs without a billet block, it'll probably cost the same or more
07-20-2020, 04:56 PM | #12 |
Rep 500
If you really want to bring the weight down, broccoli and eggs diet!!
Rear sway is what...... 10 lbs. *delete* Unbolt all the exterior panels off the car as they are all over-rated cosmetic items. Take out the glass...... overrated when you are wearing your skunk-works helmet. So many opportunities all for free...... except the eggs and broccoli diet. . |
07-21-2020, 01:21 PM | #13 | |
Rep 375
07-22-2020, 03:36 PM | #14 | |
Rep 3,004
And....
-Remove the gas tank and install a one gallon gas tank -Remove one head light and tail light -Remove the passenger seat -Remove the battery and push start it -Remove one of the mufflers -Remove one of the side view mirrors -Remove one of the kidney grills
Racerbruce
07-22-2020, 04:26 PM | #15 | |
dances with roads
4732
Rep 4,096
