03-17-2021, 11:15 AM | #1101 |
Rep 1,543
In-ground, pop-up sprinkler head? Haven't done it myself (yet) but doesn't look too bad. Lots of YouTube videos on it. Dig, remove, extract, insert, adjust, replace dirt/grass.
- Jeff
bosstones' flickr |
03-17-2021, 11:19 AM | #1102 |
"Salud"
13881
Rep 4,679
Drives: F01 & F15 / Mineral White
My latest project... Avocado!
So this is something I've been interested in trying for years! I recently opened a rather large fruit and the seed was already cracked and sprouting! Which if you've read up on these, that's one of the most difficult tasks. So I decided to clean it off and Transplant it into a starter pot. I already know it may never yield Fruit. But it still makes for a really nice Houseplant. Stay tuned...
03-17-2021, 11:27 AM | #1103 |
"Salud"
13881
Rep 4,679
My very first Redbud that I planted last Summer (which was already bad timing) also survived that Antarctic Blast and is now budding and doing lovely. 🤗
03-17-2021, 01:35 PM | #1104 | |
Rep 11,843
Drives: MY24 G01 AW Msport
i do know is that i have to replace few, when the inspector turned on sprinkler system. Few heads didnt pop up, more like low pressure fountain lol |
03-17-2021, 02:04 PM | #1105 | |
18032
Rep 9,378
The trick, I learned from a local with a bunch of fruit-producing trees, was a rusty nail driven into the trunk. |
03-17-2021, 04:32 PM | #1106 | |
Rep 685
If a head is broken but not at the base it will just unscrew, very easy takes me 3 mins to do an entire swap out. If the head is over 6 inches tall it may be side entry which isn't as easy. In that case dig the head up and around it to allow the head to be able to come completely out of the ground. Be very careful not to pull too hard or you'll break the swing fitting. Then spin off and the new one back on. Hardest part for homeowners is adjusting the head afterwards. Or the easiest step is just call an irrigation contractor. I charge between $46-58 per head replaced, labor and parts plus service call of between $45 and $90. If a lot of heads need replaced I waive the service call. Just so you know what it may cost. |
nyalpine907433.00 |
03-17-2021, 05:20 PM | #1107 | |
"Salud"
13881
Rep 4,679
But I've read up plenty and we'll see. The thing is, the chances of it actually producing fruit is slim to none. I'm doing it more for a nice attractive Houseplant. |
03-18-2021, 08:53 AM | #1108 | |
Rep 11,843
one estimate came back $3500 new heads, lines and valves. (verbal) no idea how much piping is involve, how much valves and heads are. i walked away |
03-18-2021, 11:05 AM | #1109 | |
Rep 685
Lines shouldn't need to be replaced. We do system renovations as well and I've never seen one needing that as long as it's pvc or poly. I charge $250 per valve replaced. $3500 sounds like it could be reasonable depending on system size, types and number of heads plus quantity of valves. Takes about one day to do. I had to replace all valves at a house last year. Took 7 hours, cost $2,300, replaced 7 heads and 7 valves. I don't recommend replacing valves yourself. You could do the heads which would save you some money and just pay them do the head adjustments and valves. |
nyalpine907433.00 |
03-21-2021, 12:35 AM | #1110 |
Rep 1,543
I trimmed back around 60 tallgrasses and 12-ish carex today. I bought a pair of grass scissors for that. The deed is done but, damn, factory sharp isn't on par w/ how sharp I like to keep edged tools. I might look into a sickle or a scythe for next year. lol
- Jeff
bosstones' flickr |
03-23-2021, 04:30 PM | #1111 | |
Rep 14,521
on that note i can't even put my pre emergent down because were suppose to get several days of rain and if i put the pre emergent down it could wash away
03-24-2021, 03:42 PM | #1113 |
Rep 14,521
just spent the afternoon taking the lawn down to 2" to get rid of the dead grass. used my lawn sweeper to pick everything up. if it doesn't rain tomorrow i'm gonna dethatch the lawn. suppose to rain the next day so i'll wait before i aerate than throw down my pre emergent. Springs is so close but knock on wood i'm expecting at least one more snow dump on us
03-24-2021, 08:17 PM | #1114 |
Rep 12,728
Patchy grass vibes.
Instagram; @roastbeefmike
lsturbointeg9158.50 bosstones1154.00 |
03-25-2021, 04:13 PM | #1115 |
Rep 14,521
worked on dethatching the lawn. kids weren't too excited about this because it's yard work lol!
all done! Nikko Blue Hydrangeas are starting to bud out! looks like they survived the winter my tulips are also starting to take off!
03-26-2021, 01:30 PM | #1117 |
"Salud"
13881
Rep 4,679
Compare the pic I posted above just 9 days ago to today. My Redbud is exploding with Blooms!
03-26-2021, 04:40 PM | #1118 |
Rep 14,521
got the aeration done yea!!!! waiting for better weather to do some Spring pruning
03-27-2021, 06:08 PM | #1120 |
"Salud"
13881
Rep 4,679
03-28-2021, 10:10 AM | #1121 |
Rep 869
Our03Z4 quick question.
I have a landscaper who handles the whole years but I still do so small projects and check some stuff. For example if I see a brown spot I’ll add some tine to that zone. I’m thinking about installing a Ratchio sprinkler clock so I can change setting on my phone. It should make it easy to check heads and coverage without running back to the clock. Any suggestions ? |
03-29-2021, 06:07 PM | #1122 | |
Rep 685
All in all if it will just be you using the controller the Rachio will be fine, but if you have a contractor that ever needs access then you're better off with the Hydrawise. I honestly don't understand the draw for everyone wanting the Rachio. |
