11-23-2011, 04:05 PM | #45 | |
instagram 997turbotom
279
Rep 7,376
11-23-2011, 04:21 PM | #46 |
Rep 784
Drives: 2011.5 E90 M3
The microphone mounts are generally used to keep a mic steady without external forces trying to bounce it. Seems like it may cause even more vibration if it starts resonating.
11-23-2011, 04:55 PM | #47 |
279
Rep 7,376
Thanks for the heads up. I think picking the right resistance RC suspension would be very challenging, so I'll start with those special washers
11-26-2011, 04:56 PM | #48 |
Rep 912
How do you shift so fast 1st-2nd ?
i don't see the slight pause that i need to do in order not to grind. Can you please elaborate roffle? Do you have an SSK or some transmission mounts or different transmission fluid? |
11-26-2011, 05:26 PM | #49 | |
279
Rep 7,376
Thanks for the compliment, I'll make some better ones of the shifting =)
11-26-2011, 05:35 PM | #50 |
Rep 912
this one :
@26 secs You make a quick shift, i normally have to pause half a second here and then 2nd gear would shatter the earth underneath and hell will freeze over. yet you make it so smooth and peaceful as if you were not thinking about the shifting at all. |
11-27-2011, 09:15 PM | #51 | |
Rep 476
Absolutely awesome rig, never seen any real-world video from this perspective. I can't wait to see more productions with it, even without further stability improvements |
11-27-2011, 10:36 PM | #52 | |
Rep 476
That said, I think there could be great success with software-based image stabilization, especially if the video is shot at 60 or even 120fps (the original GoPro HD can do 60fps at 720p, and the new HERO2 supports 120fps at some resolution). I would do this in Final Cut Pro, but there are probably simpler software packages available that can do it. This technique will sacrifice a margin around the border of the video because it effectively needs to crop frames in different places and then translate them horizontally and vertically to line up with the previous frame, but I don't think it would need to crop enough to be really detrimental to the awesome effect! |
11-27-2011, 10:45 PM | #53 |
279
Rep 7,376
thanks man! Good tip about shooting at 60fps. I'll have to "buy" finalcut pro, but I doubt I'm smart enough to learn it. But then again I just need it for one function. Let me know if you find a simpler program, maybe one that just specializes in image stabilization
11-27-2011, 11:11 PM | #54 | |
Rep 476
Do you have a Mac or a PC? I didn't immediately find a good stand-alone solution with a brief search on the web. iMovie is a lot cheaper / comes with Macs, and almost certainly has video stabilization filters as well. |
11-28-2011, 01:36 PM | #55 |
Accidentally in BMW
15
Rep 221
Wow! That's a great combination of ingenuity and, frankly, guts!
I really enjoyed the ride-along. I also appreciate what a little extra power might be like... I offer the following only because you seem to be "handy" and might want to pursue this further. Here's a simple gimbal design using a skateboard bearing and PVC: http://www.yb2normal.com/DIYsteadicam.html The gimbal will add weight but your latest design may be robust enough. You'll have to decide of course. Although there are a few DIY shock-cord mounts similar to a mic cage, I would agree with the comments above that oscillation at speed will likely make things worse and, under extreme conditions, tear the camera loose. The gimbal design shows promise, however. Best regards. |
11-28-2011, 03:58 PM | #57 |
Rep 784
Take a look here for more inspiration: http://www.filmtools.com/succupmoun.html
Here's an excerpt from the page... "Note: The beefier the mount, the less harmonic vibration will occur. More mass = less harmonics and vibration." |
11-30-2011, 03:58 PM | #58 | |
279
Rep 7,376
11-30-2011, 06:52 PM | #59 | |
Rep 208
11-30-2011, 11:21 PM | #60 |
279
Rep 7,376
heh, that bridge is tight.
You gotta stop by warminster sometime and teach me the best way to launch this car, and/or switch cars for a day
12-06-2011, 08:17 PM | #61 |
279
Rep 7,376
well... building that guibo thing was a waste of time and $40. Once I got it together I realised that the whole center mass with weights will just swing forwards and backwards as the car accelerates and decelerates. Not to mention it doesn't quell small vibrations too well. Its good for walking around the house like in the sample video... I guess
Going to order those washers next
12-07-2011, 08:45 PM | #65 |
279
Rep 7,376
18x9 Volk TE-37 in flat black. With ltw spacers making it et 38 in the front, et 20 in the back. Bridgestone RE-11, 265/35/18 all around, with -2.5* camber all around
H&R springs pics here http://www.zpost.com/forums/showthread.php?t=598658
