05-05-2013, 12:58 PM | #1 |
Rep 1,100
Camber off After Bearing Replacement
I am stumped as to why the camber is off on my car after the rear bearing replacemnt. I was wondering if you could offer some advice as to what could be the culprit. The camber is off on the left side of the car. Its at 3 degrees while the right is at 2.6. (z4 non m have high camber from the factory.)
The only thing I did differently on the left hand side is remove the left side half axel shaft. |
05-05-2013, 10:26 PM | #2 |
enthusiast
48
Rep 1,695
Bearing replacements often require banging with heavy devices and it doesn't take much to make a car out of alignment.
That's all I could think of. |
05-05-2013, 11:52 PM | #3 |
Car Geek
3626
Rep 3,592
If bolt 10 and nut 11 in this view of the rear suspension were loosened during the bearing replacement, your camber will likely be off: http://realoem.com/bmw/showparts.do?...39&hg=33&fg=30.
Adjust your rear camber by rotating this eccentric bolt and nut after loosening, then re-tighten when the camber is correct. Rear toe may then need to be adjusted by loosening 3 bolts marked as 19 on the above diagram and moving the trailing arm mount. |
05-06-2013, 04:28 AM | #4 |
Rep 222
^ WHS.
Unless you marked the position of the eccentric bolt before you started it will be a matter of luck if you'd managed to refit in the same position afterwards. |
05-06-2013, 09:37 AM | #5 | |
Rep 1,100
