03-25-2013, 11:18 PM | #1 |
Rep 501
Creaking from front end
Please forgive me, as I am 1. not very mechanically inclined, and 2. brand new to the E85 platform.
I just got my Z4 M Roadster last week. There is some very noticeable creaking coming from somewhere up front. It is most noticeable while driving at low speeds when the body would flex. My first thought was "it's a roadster, it's bound to creak a little" but this seems really excessive. I realize that this is not much useful info from me, but are there any areas in this platform that are common to cause some the symptoms that I have? Or some more info/feedback that you'd like from me to help diagnose this? |
03-26-2013, 10:47 AM | #3 |
Rep 501
Thanks. I checked the braces and they seem tight. After I closed my hood, I happened to press down on the driver's side front corner and noticed that there was a little bit of play and that there was a bit of a creaking sound. Not sure if it's the same creaking that I was hearing (I should have had someone press down while I was in the driver's seat!) but I ended up putting a little grease on the driver's side hood latch, which seemed to quiet down the creaking. I'll see if that changes anything, and I'll report back.
03-26-2013, 01:55 PM | #4 | |
701
03-26-2013, 04:14 PM | #5 | |
Rep 1,663
As for your firewall braces, how did you check? More than one person on here (including me) has made the mistake of thinking they're tight without torquing them down. It's not until you get the torque wrench out that you can really see if they're at the correct tightness. This is assuming you have the old "nut" style braces, rather than the updated one-use bolts. So if you haven't taken a torque wrench to it I suggest you do that first.
03-26-2013, 05:29 PM | #6 |
Rep 501
I've got a torque wrench, but I'm having difficulty finding torque values for the old style nuts, which I believe I do have...
Also, that failed bump stop symptom sounds exactly like what I was feeling at the front driver's side corner of the hood. So I'll definitely check that out. Thanks! If anyone can point me in the right direction to find torque values for the old style nuts please let me know. I'll probably use some blue Loctite as well. |
03-26-2013, 06:05 PM | #7 | |
701
03-31-2013, 12:15 AM | #9 |
Rep 501
Thanks Finnegan and beta!
As suggested, I checked the bolts even though the braces seemed very solid, and sure enough one bolt was a little loose. After tightening it down, the creaking is gone. Also, I did check the hood bump stops and one is broken. I picked up a new one today and will swap it out soon. Thanks again, 2 things solved in one thread |
03-31-2013, 01:47 AM | #10 |
Rep 1,663
Glad it worked out for you!
If you want a more permanent solution to the braces, check out my mod thread for Nord-Locks + anti-seize. So far I haven't had to re-torque them.
