      12-09-2019, 11:27 AM   #1
Donkman
Drives: 2005 BMW Z4
First time installing a Pioneer SPH-10BT
I am going to attempt to install a Pioneer SPH-10BT into my 2005 BMW Z4.
I am going to use a Crux SWRBM-57K, so I will keep my steering wheel functions. I will be running new wires from the new radio to the trunk and hook up the the outside on the existing amp.
My questions are, wires from radio to ?? (find location of in my Z4).
LIME Green to Reverse signal input
Violet/white to Parking Brake
Thanks
Donkman
      12-09-2019, 12:42 PM   #2
cbecker33
Drives: Z4 M Coupe
I can't help with the wiring but would love to see a photo and hear your thoughts once installed.
      12-10-2019, 10:55 AM   #3
Donkman
Drives: 2005 BMW Z4
Thanks
Donkman
This is what I have found so far. Anyone confirm please?
: Parking Brake : Blue/Brown/Yellow, Parking brake switch or cluster. Pin # 2
: Reverse signal input : To Blue/Yellow at kick panel or cluster. Pin# 22
      12-11-2019, 12:14 PM   #4
rsutoratosu
Drives: Z4 3.0i
Not 100% sure, but you're looking for the pin out of the line running into radio ?
see if this helps
https://www.tehnomagazin.com/Auto-ra...-Connector.htm
-Roranji
      12-11-2019, 02:27 PM   #5
Donkman
Drives: 2005 BMW Z4
see if this helps
What I need is where to hook up the LIME Green wire from the new radio to the Parking Brake
and
where to connect the Violet/white wire from the new radio to the Reverse signal . ( Only needed if using a backup camera)
      12-22-2019, 04:12 AM   #6
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1593
Drives: 2007 Z4MC
parking brake is blue/white. nfi about the rest, just chopped it.
Powered by
      12-22-2019, 07:28 AM   #7
Donkman
Drives: 2005 BMW Z4
Vanne , Where did you find the Blue/White wire? did you need to disassemble the console?
PS, Vanne told me it is under the shift boot, no need to remove console.
Search this Thread:
Advanced Search
