      03-29-2019, 07:16 AM   #1
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Dynamic Brake Control (DBC)
Hope someone on here has some experience with coding out the DBC in our cars.
http://www.bmw.com.kh/asia/en/insigh...e_control.html
Always found our cars require an extra light touch on the brakes in a track environment.
Recently, read about this feature and believe it may be the root of it.
Hoping someone has done it and can feedback any observed changes.
Thanks!
      03-29-2019, 08:51 AM   #2
ga41
ga41's Avatar
Cyprus
27
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
A few people on Z4-Forum have done exactly that.
https://z4-forum.com/forum/viewtopic.php?f=9&t=103844
      04-02-2019, 05:18 AM   #3
Vanne
Vanne's Avatar
United Arab Emirates
986
Drives: 2007 Z4MC
You can also over come this by being gentle with the trottle. Buy I agree, coding it out is the way to go.
      04-02-2019, 08:48 AM   #4
Michael9218
Drives: 2007 Z4 M Coupe
What are the symptoms of this DBC interference?
I can't say that I've noticed anything amiss with my brakes on track.
      04-02-2019, 10:43 AM   #5
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Does DBC always remain on? Even when all traction control is turned off?!
      04-02-2019, 01:00 PM   #6
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Basically the brakes are inconsistent in their sensitivity. If you come off the throttle hard and go right on the brakes, the DBC system builds pressure so you get maximum (feels like it) braking with less pedal travel, thinking you're in an emergency situation.
That's why what Vanne suggested should work. If you are gentler off the throttle it likely won't activate DBC.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red
      04-02-2019, 03:48 PM   #7
Michael9218
I wonder if my custom tune has this turned off. I definitely abruptly go from WOT to hard brakes and haven't noticed anything inconsistent.
      04-02-2019, 06:51 PM   #8
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
In certain situations, it feels like the braking system is over boosted with minimal peddle movement to reach maximum brake and very little modulation.
Hoping to find someone locally to code this out.
      04-29-2019, 07:24 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
I get this a lot during "normal" street driving.
Never learned to properly heel-toe, so I go from brake to stab the gas to brake very quickly on downshifts.
When I get back on the brake 50% of the time I get "hyper-brakes".
      04-30-2019, 01:04 PM   #10
Azeka1
Track Junkie
Azeka1's Avatar
Albania
233
Drives: E86 M Coupe
Same here - I specifically went back an analyzed my data overlaid on my videos and cannot see any signs of this at the track. I do however prime my brakes with my left foot when entering hard braking zones so perhaps that helps... or maybe the previous owner removed it.
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | SS Headers | Rouge Exhaust| APEX ARC-8 | APR Aero | Sparco Seats/Belts | Weichers Cage | Solid Motor/Trans/Shifter/SubFrame | Poly Bushings | Race Camber Plates/Arms | CSF Rad/Oil | BW Brake Ducts | Braille Battery | AC/EGR Delete | 3,100lbs
1991 SW20 MR2 Turbo | Widebody | 400WHP/355TRQ | 2017 Audi Q7 | 2010 VW CC 2.0T
Gone: 2014 Audi A6 | 2011 G37 S Coupe 6MT | 2004 G35 Coupe
