      05-19-2013, 12:27 PM   #1
thelinux
Drives: 2008 Z4 3si
brake pad sensor
I want to replace brake pad sensors. I took off tire and examined old sensor to find where the connector goes (Not the pad side, but the other side). The wire goes into body (under door) saw can't see where the connector is. How did you guy do this? Do I have to take out some trims to expose the connector?
Thanks.
      05-19-2013, 06:06 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I assume you mean the rear sensors.
You can get to it from underneath, right behind the RTAB
      05-20-2013, 06:38 AM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
Why do you need to 'replace' the brake pad wear sensors?
Just unclip the hinged cover on the 5" long rectangular box (see picture below under the red arrow). Disregard the other circles in the picture.
The sensor cable now just unplugs.
      05-24-2013, 05:45 PM   #4
thelinux
Drives: 2008 Z4 3si
Thank you guys. I was looking to find one for rear and I found it. It was behind the wheel well cover. Thanks.! :-)
