04-11-2013, 03:31 PM | #1 |
Rep 52
Drives: 2008 z4 3.0i roadster
Total toe on the street
What are you using for total toe in front for the street and why.
04-11-2013, 03:36 PM | #2 |
701
Rep 7,850
Front or rear?
Zero front. Why? -2.0. Toe in would cause excessive wear with those camber settings. Rear? Can't recall offhand, but some toe in, somewhere in the low end of recommended stock range. Why? Zero toe would be unstable/unpredictable. |
04-11-2013, 03:47 PM | #3 |
Bimmer Noob
30
Rep 566
+1!
Zero toe in the front for street. something like 1/32" toe in for the rear, can't remember Same reasons as above!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
04-11-2013, 03:51 PM | #4 | |
Rep 52
Where would the wear be on the front tires with -2.0 and toe? Thanks Finnegan The reason I ask is that I am trying to dial in my 3.0i after a hit, I have -1.3 camber left and -.2 right in the front and .1 toe and I was getting hefty tramaling?? and inner tread wear, but it handled and rode quietly. I know I need to get rid of these RFT's.... Last edited by NHZED4; 04-11-2013 at 04:04 PM.. |
04-11-2013, 05:01 PM | #5 | |
701
Rep 7,850
Stock settings and ranges for the 3.0 can be found here. Toe isn't that extreme either, and -1.3 isn't enough negative camber to not consider some small amount of toe in. Camber left/right should be, IMO, within .1 on either side. Can isn't handling up to it's potential with those whacked settings. If your shop can't get anything better than that, you probably have bent/compromised suspension components (best case) or other structural damage (worst case). If its structural, I think it's possible that the entire car could be "crabbing" down the road, regardless of alignment settings, and that would really mess up tire wear (and handling). If you have more data on the "hit", let us know. If not, you need to work backwards from the alignment to the suspension and so on to determine where the issues are and correct at that level. |
