      11-30-2012, 09:56 AM   #1
Sirhan
Drives: Z4 M Coupe
///M Grill ?
Guys
Apologies to JB007 for using his car in this very disgraceful photoshop edit. Has anyone seen a grill that I am trying to create here?
      11-30-2012, 09:59 AM   #2
Beedub
yes.... they are a vinyl overlay kit.....
http://www.bimmian.co.uk/M-Colored-G...r-E91-3-Series
i think these look GREAT on darker cars... its a nice touch imo!!
      11-30-2012, 10:16 AM   #3
Drives: Porsche Cayman
I was able to match M badge colours to some vinyl at a local trim shop
      11-30-2012, 12:03 PM   #4
SD ///M4
///Multiple
SD ///M4's Avatar
I did this on my car, although I have the stripes on the middle three slats so the stripes are centered in the grille opening on the left side which I think looks the best. I also have flat black grilles and the car is Interlagos Blue.
I initially found some vinyl tape from an archery source online (apparently archers like to wrap their shafts with different color tape ). Unfortunately, the Z4's slats are more like vanes or fan blades. They're angled, aren't flat nor do they have a consistent width from top to bottom. I used several horizontal strips of tape but the seams were pretty obvious at anything closer than about 20 feet. But I liked the effect.
Not liking how the vinyl tape looked, I bought the the Bimmian kit. It consists of five thin strips of each of the three colors. They're really designed for the E36/E46/E9x grilles where the slats are straight, thin, flat, and have a consistent width. Because of the shape of the Z4 slats you have to kind of center the thin strip and follow the contour of the slat. You can't use multiple strips because again the seam would be obvious. The thin stripes are subtle yet still stand out.
A fellow club member has a white E46 M3 with M color graphics on his car and he gets his vinyl from a local print shop. He gave me three 6"x6" pieces, one of each color in case I want to completely wrap the slats. To do this you need a piece about 2" wide and a little less than 6" high.
I'm liking the way the Bimmian strips look for now.
His: 2016 M4 Coupe | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
Hers: 2018 M3 Sedan | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
Ours: 2006 Z4 Roadster | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      11-30-2012, 12:57 PM   #5
No_Dominion
No_Dominion's Avatar
100
Drives: 2007 Z4M Coupe
Classy, I dig it.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides
DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake
MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS
      11-30-2012, 01:03 PM   #6
...... Unfortunately, the Z4's slats are more like vanes or fan blades. They're angled, aren't flat nor do they have a consistent width from top to bottom. I used several horizontal strips of tape but the seams were pretty obvious at anything closer than about 20 feet. But I liked the effect.
FWIW, with a bigger piece & a little heat you can wrap the blade around to the back side.
      11-30-2012, 04:03 PM   #7
Sirhan
Drives: Z4 M Coupe
I would personally wrap the entire blade as apposed to a single strip. It would looks sick on a black car .... cant wait to get cracking on mine.
placing the strips in the centre of the grill look better than to the side.
      11-30-2012, 04:15 PM   #8
IDK... I think I like it better on the side like your 'art' work.
In the middle is a little too symmetrical for a car with attitude
The side blades are more angled as well.
      11-30-2012, 07:59 PM   #9
SD ///M4
///Multiple
SD ///M4's Avatar
The vinyl tape, same size as black electrician's tape, was too narrow to wrap around. In these colors it only came in this "standard" width. The only way to cover the slat completely was to use several horizontal stripes, which didn't look very good because of the seams.
If you want to wrap completely around to the back you need a strip about 2" wide.
      11-30-2012, 08:54 PM   #10
Thanks
      11-30-2012, 10:52 PM   #11
Sirhan
Drives: Z4 M Coupe
[QUOTE=inTgr8r;13080263]IDK... I think I like it better on the side like your 'art' work.
ART work
well i think you may have a point about pushing the strips to the far right because it offers more angle, I am making mine matt black next week and then will work on the strips after that.
For the strips i will use a custom wrap, get it professionally done, thoughts on this anyone? get it done by these guys http://www.greensky.co.za/
      08-20-2019, 09:36 PM   #12
TAL2GK
TAL2GK's Avatar
110
Drives: 2006 Z4M Coupe, 2017 911
Reviving this very old thread because Id like to remove mine and go back to OEM look. I bought The car this way.
Any idea best way to remove? Hair dryer and start peeling?
2003 Z4 2.5i Roadster (SOLD)
2006 Z4M Coupe
2017 Porsche 911 C2S Cabriolet
      08-21-2019, 02:57 PM   #13
Azeka1
Track Junkie
Azeka1's Avatar
Albania
233
Drives: E86 M Coupe
I could be wrong but yours appears to be an actual replacement kidney grille with the stripes painted on. If that is the case, you would need to get a replacement set.
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | SS Headers | Rouge Exhaust| APEX ARC-8 | APR Aero | Sparco Seats/Belts | Weichers Cage | Solid Motor/Trans/Shifter/SubFrame | Poly Bushings | Race Camber Plates/Arms | CSF Rad/Oil | BW Brake Ducts | Braille Battery | AC/EGR Delete | 3,100lbs
1991 SW20 MR2 Turbo | Widebody | 400WHP/355TRQ | 2017 Audi Q7 | 2010 VW CC 2.0T
Gone: 2014 Audi A6 | 2011 G37 S Coupe 6MT | 2004 G35 Coupe
      09-01-2019, 08:17 PM   #14
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
M stripes
Just paint the front bumper
2013 X5-35d - Platinum Grey / Oyster; Premium - Sport
2007 BMW ///M Coupe
RETIRED 2006 TiAg E90 330i - Black leather - Alu Trim - Prem - Sport - NAV - Step - CA - Heated Seats
