09-28-2011, 12:11 AM | #1 |
Rep 266
Z4M roadster coilover and rear adjustment
Hi all,
I am planning to upgrade my stock suspension for track use. I do about 5~7 trackday events. I would like to know how easy to access the rear shock setting knob. Last time I looked, it looks like the soft-top sits right on the rear shock mount making it pain in the butt to change the shock setting. If you know an easy way, please let me know. Thank you.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual 2006 BMW 330i 6spd manual - gone |
09-28-2011, 01:12 AM | #2 |
///M-fanatic
193
Rep 3,885
hey Chun! Get Rogue Engineering RSMs. They invert the rear shock towers so you can access from the bottom side. Also, get coilovers that have adjustment elsewhere
09-28-2011, 04:01 PM | #3 |
Rep 266
Most likely I will get the TC Kline DA system that comes with inverted RSM. My main concern is being able to adjust the rear shock without removing the soft-top everytime. I see a lot roadster ppl with coilovers, I would like see if they have any trick to do it without spending hours taking soft-top components out.
2009 BMW X5 4.8i
09-28-2011, 05:55 PM | #4 |
///M-fanatic
193
Rep 3,885
I wasn't aware that the TCK D/As came inverted? Or is this only for their newer designs?
I don't recall if mine were inverted. Totally forget lol. I don't tweak mine as you can obviously tell |
09-28-2011, 06:47 PM | #5 |
Rep 266
YOu are right.. it isn't inverted...
2009 BMW X5 4.8i
10-03-2011, 03:03 PM | #7 |
Rep 266
Thanks l4zy.. I think that is what I will have to do as well. I really don't care how my trunk looks. Thanks a bunch! you saved my Z4M!
2009 BMW X5 4.8i
10-03-2011, 05:05 PM | #8 |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
no problem
by the way where in cali are you and who do you track with? chances are i'll run into you on a track day if you are in socal...lol
10-03-2011, 09:19 PM | #9 | |
///M-fanatic
193
Rep 3,885
In the SF Bay Area, we've got a good small group of Z4Ms: myself (Lon) - titanium silver coupe runnerx (Chun) - imola red roadster me & Chun's friend Andy - alpine white coupe me & Chun's friend Shawn - silver gray coupe dorifto88 (Mike) - interlagos blue coupe gferil (Gernard) - silver gray coupe jd1plt (John) - interlagos blue coupe iPhoneEngineer (Scott) - silver gray coupe and others that I can't think of off the top of my head at the moment (perhaps because we haven't met in person, or they're not as active of forum members/buddies ). Only a handful of us track our cars, but more and more want to join in eventually |
10-05-2011, 02:41 AM | #10 |
Rep 881
awesome! you guys have a decent group!
hey what organization do you go with when you go to laguna seca and about how much are the track days? i want to go there eventually as a driver rather than a spectator so im gathering info. maybe i'll see you there one day
10-05-2011, 11:37 AM | #11 | |
Rep 266
Thunderhill - $125 Laguna Seca - $175 BW - $99 Looking forward to meet you at Laguna Seca.
2009 BMW X5 4.8i
10-05-2011, 01:09 PM | #12 |
Track Head
24
Rep 503
Trick is to do like above, except only cut a Slit in the shock cover carpet and remove a bit of the foam so you can get to the knobs.
[ <--- something like this, so that it folds over, when you're adjustment is made the carpet flops back over in place and isn't as unsightly.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning |
10-05-2011, 01:34 PM | #13 | ||
Rep 881
10-05-2011, 03:43 PM | #14 |
///M-fanatic
193
Rep 3,885
Yeah I say FUCK THAT!!!
It's expensive enough to maintain our cars lol! NCRC is the absolute best group I've been with. NASA puts on good events too, but they charge a lot so they can hire a bunch of instructors etc. I'd go with NASA if I were a beginner and wanted to get up to speed as soon as possible. But for just open track days with no hassle, and good people? NCRC all the way! Trackmasters is kinda like NCRC, but @ NASA prices Last edited by mfanatic325; 10-05-2011 at 08:16 PM.. |
10-05-2011, 06:13 PM | #15 |
Rep 266
^^ he does not lie...
2009 BMW X5 4.8i
09-30-2013, 12:54 PM | #16 |
Wagon life
39
Rep 991
10-25-2013, 03:28 PM | #17 |
Rep 279
At the bottom of each knob there is a small strut which runs to the side of the knob and is connected with a push pin rivet.
Pull pin out of rivet and remove. This frees the strut. Now pull straight back on the knob. It is connected to a thin rod which attaches the bottom of the shelf hinge to the plastic piece which sits atop the rear shock mount. The bottom of the hinge is now free. The top of the hinge clips into the bottom sides of the shelf. Carefully "pop" the hinge out of these clips. The hinge carrier(plastic piece which sits atop shock mount) has a 10mm bolt at it's front(by front I mean towards the front of car). It is held at rear by a torx bolt(27 or 30?) and a push pin rivet on top. Once all fasteners have been removed hinge carrier can be removed by pulling in and back and up. It's kind of a pain and needs to be finnaggled up over the shock mount and the other plastic dome that caps it. I ended up removing both plastic "domes" with a dremel and snips so I am able to access the adjustment knobs on my new shocks from the interior with top up and the shelf reassembled. Just took my time, lots of light, try not to break anything, and make sure front tab on shelf is in it's slot so it hits the micro switch. HTH's
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
04-10-2019, 04:10 PM | #18 |
Rep 342
Hey there... I realize this is an ancient thread, but I am researching coilover options for my Z4M Roadster. It seems as though adjustment on the rears is a pain in the arse given that the soft top has parts of it that sit on top of the shock mounts / adjustment points.
What is the impact of leaving those parts out? Does the soft top still function without issue? Thanks in advance... hopefully someone sees this thread rise from the ashes Cheers, Eamonn aka eggman |
04-19-2019, 09:58 AM | #19 | |
Rep 264
I wanted to keep as much of the trim as possible and retain the shelf, so what I ended up doing (since I had a spare set) was to drill out a hole in the rigid plastic hinge mechanisms and pliable rubber/plastic covering exposing the top adjustment knob at the raised, curved section. This allows me to make adjustments without needing to remove anything, though the top does need to go up to make these adjustments. Obviously, this is a more permanent modification, so the decision is up to you. I figured if I ever go back to stock I would swap in my spare hinge mechanisms and put rubber bungs in the pliable stuff.
04-19-2019, 10:29 AM | #20 |
Rep 342
Thanks very much for the reply. I think I will make that same modification as you did. I might try run extenders through the hole. Different brands of suspension seem to have different methods of adjustment, but your mod seems to make the most sense. If returning back to stock those plastic parts can likely be found cheaply.
Do you think extenders run through those would interfere with top operation? Thanks again for the reply. Eamonn aka eggman |
04-19-2019, 12:02 PM | #21 | |
Rep 264
04-19-2019, 12:50 PM | #22 |
Rep 342
Great to know - thanks again for the info.
I'm going to track my car "as is" on stock suspension. While that will give me a decent baseline, the dampers seem to show their 50k miles age, so I think within the year I will do a suspension upgrade if I find tracking the car as much fun as I used to. Cheers, Eamonn aka eggman |
