11-25-2020, 10:19 PM | #1211 |
your average JAMF
3101
Rep 4,094
'21 M2 Comp
'19 Golf R |
12-01-2020, 05:29 AM | #1215 |
Rep 509
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
12-14-2020, 05:14 AM | #1217 |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
The 3.0si has definitely earned my respect as a qualified race car. Took the car for its first race weekend with BMW CCA club racing at Roebling Road. The car performed like a champ, we still have a few things to work out, but overall very happy with the results
12-14-2020, 09:41 AM | #1218 |
Rep 3,004
SO awesome.
For the unlearned, perhaps you can tell us about a few of the highlights of the HP class....safety rules (cage, seat, etc), engine, suspension.
Racerbruce
12-14-2020, 04:42 PM | #1219 | |
Rep 506
I have attached the CCA Club Racing Rules. All cars require a 6 point cage, safety etc. The key is the HP to Weight Ratio and the higher you go up the more modifications you can do. I built this car for WRL endurance series and BMW HP. the 3.0si you can get up to 285 to 295hp with a full set up, the key is the M3 with the S54 is in the same class but has to be almost 200lbs heavier. So HP/Weight becomes a bigger factor, as well as reliability. We still have a lot of tweaking to do but the car is a blast to drive. My other car which is be build for C-Mod has no weight restrictions and has a fully built S54 Stroker Motor. That will be a site to see. If you have any other questions feel free to DM me.
SPORT AND PREPARED A. Vehicles of the same engineering designation (for example, E36, E46), type (for example, 325, 330, 318), configuration (for example, two-door, four -door, all-wheel drive) and horsepower will be weight equalized to the lowest of the model year factory weights. B. Cars will be initially classified based upon published factory stock weight (pounds) and published factory stock power (SAE bhp) using lbs./bhp ratios as follows: G = Under 10.00 lbs./bhp H = 12.50 to 10.00 I = 12.50 to 13.99 J = 14.00 to 16.59 K = 16.60 to 18.99 L = 19.00 to 22.49 M = 22.50 and over 2. MODIFIED A. Cars will be classified based upon actual engine displacement as follows: A = over 5000.000cc B = 3499.001cc to 5000.000cc C = 2980.001cc to 3499.000cc D = 2199.001cc to 2980.000cc E = 1800.001cc to 2199.000cc F = under 1800.000cc https://bmwccaclubracing.com/wp-cont...2020_v.6.1.pdf |
pyshin110.50 racerbruce3853.50 |
12-14-2020, 05:08 PM | #1220 |
Rep 3,004
Greetings M-Cast and thank you for the very detailed response.
If I'm reading this correctly, did you remove appx 150 lbs from the E86 (car 84) race car?? That alone must have really affected its handling, braking, turn, in, etc. Just curious, what is the appx weight of the 6 point cage and how this weight added high in the car affected center of gravity, handling, etc. What is the engine redline and what is the RPM that you upshift?? Perhaps they're two separate answers. Really appreciate your correspondence....for those that only dream of a race car, this gives us insight into the real thing.
Racerbruce
12-16-2020, 05:20 PM | #1221 | ||
Rep 506
Redline is revs are at 7200. Switching from the 3.46 to the 3.73 made a huge difference in the rev range. |
racerbruce3853.50 |
12-19-2020, 10:12 AM | #1222 | |
Rep 3,004
Thank you -
Thank you for including us.
Racerbruce
12-19-2020, 10:27 PM | #1223 |
CLTMCarGuy
429
Rep 129
Drives: Z3M Roadster, Z4M Coupe, M3G80
What a thing of beauty!
racerbruce3853.50 |
12-22-2020, 07:53 AM | #1224 |
Rep 57
here are some new pics!
v3.2mc94.00 pyshin110.50 Cyclops1473.00 W///7494.00 racerbruce3853.50 Blackbox88881.50 StigJ333.00 Ducguy46429.00 Blakkflame43.50 |
12-22-2020, 11:16 PM | #1225 |
Rep 700
It's been a while.
12-24-2020, 02:37 PM | #1226 |
Rep 177
///Merry Christmas.
01-07-2021, 03:15 PM | #1227 |
Rep 506
First track day of the year
01-07-2021, 05:50 PM | #1228 |
Rep 3,004
Wowie!
YAY M-Cast!
SO great to start the year with this incredible black scalpel....
Racerbruce
01-18-2021, 06:56 PM | #1230 |
Rep 12,310
Took the car out on a nice long drive on the Blue Ridge Parkway after being parked for over a year (fresh rod bearings). I've missed this car so much
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
01-28-2021, 09:10 AM | #1231 | |
Rep 1,373
The Blue Ridge is so amazing.. try to drive it once a year while stopping at all the cool other roads along the way to FL
07 Z4 M Coupe AW/IR |
W///7494.00 |
02-17-2021, 11:57 AM | #1232 |
Rep 2,867
The Z has such a timeless design. Some thinks the nose is too long, but I think it's perfectly proportioned!
