      11-12-2012, 03:29 AM   #23
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
No prob! I noticed when I reorganized my ftp site I broke the links to the pictures. I'm way too lazy to fix links right now, but the color change after 3 years and xXXX miles makes a big difference!
      03-15-2013, 05:35 PM   #24
thelinux
Drives: 2008 Z4 3si
Any chance you could fix the link to pictures???
      08-25-2013, 05:50 PM   #25
thelinux
Drives: 2008 Z4 3si
As soon as the vent screw starts to burp coolant tighten it shut. As the pump turns off and on continue to top off the resevior with fresh water.
Drain the system (1st flush)
Refill w/ distilled water and cycle vent mode
Drain the system (2nd flush)
When do you stop pumping and drain exactly? When no more top off necessary? Is that when you drain and refill to do 2nd flush?
      08-05-2018, 11:23 PM   #26
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
This thread was very helpful for me. I have a Z4M with almost 60K miles. I have been changing out all of my fluids for Inspection II. While changing out coolant is not on the Inspection II list, not knowing the full maintenance history on this car, I feel better about changing out all fluids, including coolant and power steering.
I was only able to get out about a gallon of coolant. It looks like the M's only have a 8.0L/2.1gal capacity, so about half the total capacity drained out. I was tempted to do a 2nd flush with distilled water, but my old fluid was looking pretty good, so I just did one. I have quite a bit of coolant and distilled water left over. Those with M's only need to get one gallon of coolant. Two gallons of distilled water to do one water flush, three, if you want to do two flushes. The other difference with M's is that there is only one plastic drain plug. There is not one on the expansion tank.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      08-07-2018, 09:19 AM   #27
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Originally Posted by gpraceman View Post
This thread was very helpful for me. I have a Z4M with... The other difference with M's is that there is only one drain plug. There is not one on the expansion tank.
You mention only one drain plug. Did you drain the block? (that could be called a "2nd" drain plug)
      08-07-2018, 11:21 AM   #28
gpraceman
gpraceman's Avatar
No, I meant the plastic drain plugs. M's only have the one on the bottom of the radiator and not one for the expansion tank. I did not want to mess with the block drain.
      08-09-2018, 09:46 AM   #29
rsutoratosu
Drives: Z4 3.0i
How time flies, I did this 3 years ago.. I guess to keep up maintenance, Ill do this again when it gets cooler out..
-Roranji
      05-04-2019, 08:10 AM   #30
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
A few months ago, looking to upgrade my Motive Power Bleeder, I found Motive now makes an adapter for BMW cooling systems using the plastic bleeder screw (most BMWs since the mid 1990's have the plastic bleeder screw). The brass fitting screws into the bleeder screw hole so the cooling system can be pressurized. I think that the block can be drained using this method vs. removing the cooling hose that goes into the right side of the engine block. Note, I've not tried this method yet, but will soon.
https://www.motiveproducts.com/colle...iator-products
