      03-28-2019, 06:04 AM   #1
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
830
Drives: 2007 Z4MC
Vanne's lightweight Interior CF door skins
Hi Guys, this thread isn't meaning to compete with the other lightweight door skin thread. This is just mine, and is a work of progress that hopefully you guys might enjoy.
First rough sketch..
Initial rough sketches included a GT3 style door pull.. even though this looked great, I couldent work out the mechanism to be of such quality that I would be 100 percent certain it wouldn't fail after a crash/fire/ When it would be 100 percent required to work. So I re-did the sketch using the OEM door openers. I believe this is THE SAFTEST option.
2x2 twill turned up today,
ordered the super strong resin. (thanks Josh
NOTE: these door skins require you to remove the armrest support from the door. (after removal of the OEM door skin) Its quite easy to remove the 3 rivets with a small drill bit. These door skins are also designed with a requirement to have the airbags removed from the door.
Disclaimer: If you don't know how to do basic modifications, then these door skins are not for you and please move along. these door skins require you to remove your airbags. I won't go into in this thread on how to do that, its up tp you to do that. I reserve the right yada yada yada..
2007 EuroSpec Z4///MC DIY Arial. Carma FF race exhaust. Cust. D///MK 6 Speed ultra SSK. CDV X. CSL 19" Rims. Apex 75mm kit. Stoptech brake lines. APR Aero. CSL intake. Epic Alpha-N. KW CS. SS sec1. 288/280. ECS power pulleys. Tillet B6Fxl. Sabelt.Varis. Brembo GT. ME STB. JB/Sachs Race SMFW .
Mirko156.50
Azeka1215.00
      04-02-2019, 07:43 PM   #2
jra
Drives: 2005 z4
Love it!
      07-05-2019, 03:08 AM   #3
Vanne
Down Under!!
Vanne's Avatar
830
Drives: 2007 Z4MC
Finally got my 2 part glass. Thx Josh
      07-07-2019, 12:46 PM   #4
Admiral001
Drives: BMW M4, Mercedes CL55AMG
nice
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, vBulletin Solutions Inc.
