Bimmerpost for Android has just been updated to version 4.3.55 with a host of bug fixes. Try it out!
      06-17-2018, 02:02 PM   #1
HTM101
Drives: 2007 Z4 Coupe
Headlight Lens Restoration
One headlight on my recently acquired car is 11 years old, the other is 1 year old. The older one appears to have a cataract, so I bought a 3M Headlight Restoration kit and got into the renewal. When I finished the project yesterday I was very satisfied with the result and stopped for the day.
Today I looked at the lens in a different light and noticed faint but obvious swirl marks on the entire lens surface. I re-did the last several steps of the process, (a) 3000 grit buffing pad and (b) the final polishing compound. I compounded the lens twice. All the swirls were still visible when viewed at specific angles.
I guessed the polishing compound to be the culprit, that it might be a bit aggressive. I drove to Autozone and purchased a Meguiars product, http://www.meguiars.com/en/professio...-remover-16oz/ . That bottle of very fine polish compound did the trick. All swirls gone and the overall finish was much glossier.
David
2007 Z4 Coupe, 2004 F350 dually, 1965 427 pretend Cobra
StickMon464.00
      06-18-2018, 08:22 PM   #2
Z4Lee
Z4Lee's Avatar
Drives: 2006 Z4 3.0i
It's all about the grit..... nicely done. and don't forget to seal or in a year you will be back to yellow
      06-18-2018, 08:28 PM   #3
HTM101
Thanks. The sealer is arriving tomorrow. Here are before and after shots.
      07-02-2018, 12:31 AM   #4
rsutoratosu
Drives: Z4 3.0i
ill need to do this also.. what sealer do you use or recommend... is the sealer something you need to reapply once every few months ?
-Roranji
      07-02-2018, 08:58 AM   #5
HTM101
I chose this product from Meguiar's. Don't know if its the best. Their text states it will last for 1 year.
https://www.summitracing.com/parts/m...t=All+Products
David
      07-03-2018, 04:54 PM   #6
rsutoratosu
Drives: Z4 3.0i
Thanks.. does it look like something you can replay more often or can't tell yet ?
-Roranji
      07-03-2018, 05:48 PM   #7
HTM101
Much too soon. I've owned the car for just 5 months, and bought it with the lens in its deteriorated condition. Previous owners probably had the car parked in the sun quite a bit.
I have a garage and now the car is parked in the garage 24/7. I drive it maybe once a week. It may be many years before I'll see the need for a re-do.
David
      07-07-2018, 12:19 AM   #8
RossBMWZseries
Instead of using a sealer, canít you just use a LaminX film over your lenses?
      07-09-2018, 07:27 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Not sure about LaminX, but I have Headlight Armor and it has about the same life span as the bare lenses, but replacing it is a lot harder than doing the old sand and buff.
      07-11-2018, 07:17 AM   #10
SwissArmy
Why so serious?
SwissArmy's Avatar
Drives: 2004 BMW z4 3.0i SMG
The best headlight restoration kit I've ever used has to be the Meguiar's Heavy Duty Headlight Restoration Kit. Comes with all you need, except a drill of course. Highly recommend it
http://www.canadiantire.ca/en/pdp/me...-0391037p.html
      07-12-2018, 12:06 PM   #11
RossBMWZseries
How bad was the condition of your headlights?
As bad as this?
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster
2013 BMW S1000RR R.I.P.
1998 BMW Z3 Roadster 1.9L SOLD
      07-12-2018, 06:07 PM   #12
SwissArmy
Why so serious?
SwissArmy's Avatar
As bad as this?
Pretty similar. Im glad I document almost everything new I try. Here you go (in June). You should honestly try it. I can pretty much swear by it
Before:
After:
      07-13-2018, 04:58 PM   #13
RossBMWZseries
Before:
After:
Good to know. I used the Meguiar's but the "not so heavy duty" version. It did a good job and it was by hand. I'll try this one and use a drill this time. Thanks!
      07-13-2018, 07:29 PM   #14
SwissArmy
Why so serious?
SwissArmy's Avatar
No worries! I can stand by that kit. It's great! Did my buddy's headlights. One kit can do 3-5 sets of headlights.
Search this Thread:
Advanced Search
