03-18-2020, 10:09 AM | #1 |
Rep 13
FS: (03 – 08) E85 – Tein Super Street Coilovers w/ Pillowball Upper Mounts
Located in Northern Virginia (area code 22026). SS Specs: https://www.tein.com/tech_info/g98.html Fully adjustable height and damping; model D2G98-U1 746 TEIN Super Street damper kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and damping force adjustment to allow the driver to dial in the suspension for various surface conditions. Additional Features: • Steel Construction • Twin Tube internal construction • 16 way adjustable dampers, compression and rebound combined • Ride Height adjustable via spring seat • Larger piston diameter for strut type front and rear (22mm) • Powder coated damper body with Zinc coated threaded section Currently version selling for $1700 on Amazon: https://www.amazon.com/Tein-DSG98-2U.../dp/B000X217KM In great condition w/ no leaks at all and pillowball mounts are smooth as butter. I sold the car before I had a chance to put these on. Boxed up and ready to go! Last edited by Wahooz; 03-25-2020 at 10:46 AM.. Reason: Price adjustment |
04-11-2020, 01:34 PM | #7 |
Rep 86
Drives: 3.0si Coupe
Would these work on E86 3.0si with sport suspension?
04-11-2020, 04:10 PM | #8 |
Rep 13
04-13-2020, 10:22 AM | #10 |
Rep 86
Drives: 3.0si Coupe
How many miles are on them? Any track?
04-16-2020, 09:50 AM | #11 |
Rep 86
Drives: 3.0si Coupe
PM sent a few days ago.
