      12-09-2019, 01:21 AM   #441
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Bought a floor foot rest for when the car is back together.
Pax side
Powered by
3GFX722.50
      12-09-2019, 11:49 AM   #442
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Amazed at how you find this stuff.
wdb4732.00
3GFX722.50
Vanne1620.50
      12-11-2019, 05:19 AM   #443
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
For rebuilding the subframe.
CMP auto engineering (aus) subframe raising alu bushings.
Powered by
      12-12-2019, 04:44 AM   #444
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
and 2 shockmount re-inforcement weld plates from AKG motorsports.
Powered by
      12-12-2019, 05:20 AM   #445
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
And then after the final 2 purchases, i think were pretty much there...
Turner Monoball race Rtabs.
and a new set of Turner 90mm studs and nuts. the current ones have been on the car for 3 years. prob time to swap em out.
And that folks.. is it for the buying spree... now gotta plug everything together.
Powered by
wdb4732.00
      12-12-2019, 10:22 PM   #446
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Pulling the condenseor today, and the secondary waterpump (if i can get to it, otherwise that bit can wait till the throttle bodies and stuff come off.) andf doing some general cleanup and seeing if i can pull some final wirring. (and ofcourse checking if the car will still start) lol. def needs a vacuum and cleanup of the leftover Hvac pieces and 10 years of collected dust under the dash. There is also the little box in the trans tunnel that i need to find out if i need to keep that or not.
Powered by
      12-13-2019, 02:03 PM   #447
wdb
dances with roads
wdb's Avatar
4732
Just kidding! Work so far looks great.
      12-17-2019, 08:29 AM   #448
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
And then a bit more work on the car today...
Airbag sensor.... Chuck!
Airbag brain.. chuck!!
Wires ... Chuck!!
Not much left now...
That's the second time through the wires/loom. Nothing there now that doesn't need to be there.
Aircon condenser...
Chuck!!
Thx for the heads up Micheal.
Tell you what though, I was sweating a bit when I went to start the car after culling all those wires....
wdb4732.00
gds52886.00
      12-18-2019, 04:19 PM   #449
wdb
dances with roads
wdb's Avatar
4732
Especially now that you've ripped out the AC!
      12-19-2019, 02:40 AM   #450
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Lol!!! :P
      12-21-2019, 09:05 PM   #451
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Spent a few hours yesterday finishing up the loom. Heat Shrinked all the ends that terminate to avoid the possibility of having any shorts. That took a while, removed a few more wires and removed the Seat plugs.
Today ill re-wrap the wire loom and zip tie it together. ( i wont fasten it down yet as the interior is going to be painted first.)
Hopefully ill also get around to reworking the dash for going back in. Needs holes cut where the cage comes through and has already been cut longitudinally to remove the bottom 1/3rd (where the AC controls were)
My mum (god bless her.. is coming over for christmas, and she is a sewing ledgend (used to be a sewing teacher in the industy) and shes going to help me do the dash.. Love my mum!!! she ROCKS!!
Powered by
eggman51198.50
wdb4732.00
      12-29-2019, 09:03 PM   #452
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Santa dropped of 2 new rear rims from Sportline. Flow formed lightweight track goodness.
Removed the cruise control yesterday too.
      12-31-2019, 01:17 PM   #453
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Yesterday's progress...
Cut open , painted and removed a lot of sparkly crap from the lights. Wet sanded the lens, sealed and lens curing atm. Will glue the whole thing back together next week.
wdb4732.00
inTgr8r2431.50
      01-07-2020, 03:15 PM   #454
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Meanwhile.... Somewhere in Dubai...
Hatch removal today. Holy shit This thing is bloody heavy!!
Installed this puppy!! Can lift the frame with my pinky.
And then left untill paint shop..
So light, I've had to remove one of the boot struts, otherwise you can't close the boot.
wdb4732.00
      01-07-2020, 04:21 PM   #455
eggman51
Drives: 2006 BMW Z4 M Roadster
That is looking so amazing!
I took my lights apart as well, so I could install custom halos and demon eyes, it was not easy, but I'm a nutter about lighting so it was worth it to have modern looking RGB capable halos on both projector units inside the housing.
Love the updates - tyvm!
      01-07-2020, 09:07 PM   #456
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Pinky's rule!
And....the massive weight loss is high on the vehicle, thus positively affecting the COG, and with the incredible amount of unsprung weight loss....this alone will have such an incredibly great affect on handling.
Have you even "gone there" in your head as to the difference in handling??
Racerbruce
Vanne1620.50
      01-08-2020, 05:19 AM   #457
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks guys..
Windows.
      01-24-2020, 02:17 AM   #458
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Did some work, that I've put off for a while as it sucks, but got stuck into it anyways. So the whole side combo set is now held on solidly by visibly only one bolt.. (there are 3 in actual fact, but only one visible) pretty darn chuffed with that.
Solid as a rock...
Thing fits together like a freaking rubic cube
Powered by
3GFX722.50
wdb4732.00
      01-26-2020, 07:51 PM   #459
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
New box arrived...
Custom brake booster delete kit just arrived.
Note the different push rod.
Also just recieved my fully adjustable tie rods.
Hopefully piecing it together over the next 8 weeks.
      01-27-2020, 11:43 AM   #460
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Curious why you want to delete brake boost?
Vanne1620.50
      01-28-2020, 05:05 AM   #461
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Hi Micheal,
2 fold really.
the first one is that if you lift off (in a hurry) the throttle, primarily the brake booster gets pre-blown (for emergency stops,, no idea if other cars do this, but mine does, and its possible to code this out), but its a bit hectic when you have to modualte from one extreme to the other. There is a way around that and probably the better way, improve your driving (i cant drive for shit, and i am always learning) and dont lift off so fast. simple.. easily said, not easily done..
the second and much more importantly, is modulation and range. This one is 2 fold. with the brake booster applied, your range is say with in 2 cm , from zero to 100%, without the brake booster, that range stays at 2cm, but the pressure required dubbles. so you have a lot more variety for modulating the brakes that you want to use. the range becomes 50% larger. and as a bonus, its now dependable/expectable, regardless of throttle use.
It does require more force to do the braking, but should become second nature very fast. The advantages far outweigh the dis-advantages. It DOES however require getting used to it. Jump in a un-assisted car and youll be like pressing for-ever, then jump into a normal car and youll feel like your pushing your face through the windscreen.
Powered by
      01-28-2020, 05:10 AM   #462
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
just ordered a lightweight cabin blower, 4" 235CFM low noise unit.
Just in case the front screen starts to mist up.
Powered by
