      10-30-2016, 10:24 PM   #199
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Originally Posted by Vanne
Thanks guys, yeah its been a bit of a hike as of late. The roll bar/strut/seat install has been finally completed somewhat, however I still need to drill 2 holes in my seat sub frame for the 5th and 6th point of the harness. The guy who made the roll bar only allowed for a single 5th point of the harness, so have to re drill 2 more holes in the member.
So yesterday, the 29th, i finally dropped my car off at Octane, to do the much overdue Vanos (refresh) and pump disc upgrade, and while the top end is apart, the install of the Shrick cams. Also while the car is there, the front right Fang intake will be replaced by a 19 core oil cooler, and the left fang intake will be re-routed directly to the CSL intake.
Sounds F'ing proper Vanne. Great plans!
-Matt
| Z4M Build Thread | @violetnites | flickr |
Vanne1620.50
      10-31-2016, 12:44 AM   #200
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Thx Matt, sadly no pics atm mate, just hope it turns out great, Randy from Epic was absolutely great, updated my tune for free. A few other bits and pieces going on the car, can you believe I finally picked up the power pulley belt finally from ECS.. ordered over 5 months ago...
      10-31-2016, 02:02 PM   #201
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
A few pics of the seats...
Powered by
      10-31-2016, 02:12 PM   #202
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
And now for a few updates on the car..
New cams and followers installed and shimmed.. more descriptions to come..
Powered by
      10-31-2016, 02:21 PM   #203
RedOctober
RedOctober's Avatar
Ukraine
33
Drives: '13 M3
interested in hearing about the tune after the cam change.
Which cam did you go with, 12.5 or 14? or another?
Vanne1620.50
      10-31-2016, 06:20 PM   #204
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
The seats look like they would be at home in a space ship! Sick build!
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
Vanne1620.50
      11-01-2016, 01:39 PM   #205
Philly_sweden
Philly_sweden's Avatar
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Omg Vanne those seats!!!!
Vanne1620.50
      11-02-2016, 01:14 AM   #206
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Vanos. Pics. Descriptions to be added later..
Power Pulley by ECS.
Powered by
inTgr8r2431.50
      11-02-2016, 10:38 AM   #207
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Coming along nicely Vanne!
Vanne1620.50
      11-02-2016, 10:50 AM   #208
F360C
Drives: E86 S54
More pics of the cage!
07 Z4 M Coupe AW/IR
Vanne1620.50
      11-05-2016, 04:12 AM   #209
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Quick and dirty update...
Nose off. GC race sway being re-painted in Red to match the body work.
Genious masterminds doing their magic fabrication and production skillz..
Spot the difference?
Furnishing supports and keeping it semi OEM looking. Intake Port fully open on this side to promote free flow. Looking for a 5 to 8 degree C drop to oil temp..
Terrible photo...
And the other side, due to much limited space, two 1.25 inch hoses, pressurised by the duct force air into the bottom extension of the CSL snorkel. Finally some added pressurised cold air..
I wish I'd taken a few more photos of this as these guys were doing a really awesome job.. this should also drop the intake temp by at least 5 degrees, possibly more, and the cold air from outside will facilitate ambient air into the snorkel too. Faster flow from below.
The hoses won't protrude into the intake, but will be flush to the surface. The top was choosen due to the max pressurising differential at the top..
As always, comments more than welcome..
Powered by
      11-05-2016, 04:29 AM   #210
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
I'll post up a whole lot when I get my car back, the finish is OEM.
Powered by
      11-06-2016, 04:53 PM   #211
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
In my opinion, that's doing it right. Awesome work on this Vanne.
◙ Shane
Vanne1620.50
      11-06-2016, 10:08 PM   #212
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
12.5 here mate, high lift needs new springs/retainers and possibly high compression pistons.. if i was gonna do that, id be investing in a stroker.
Powered by
      11-06-2016, 10:29 PM   #213
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks Shane, To be honest mate, reading your story, this does have me a little scared, i mean, my car was running great before this, i just hope it runs great after this mate. Thanks for the comments mate, means a lot.
Powered by
      11-07-2016, 04:56 AM   #214
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Powered by
      11-08-2016, 11:16 AM   #215
RedOctober
RedOctober's Avatar
Ukraine
33
Drives: '13 M3
actually, high compression pistons are completely UNNECESSARY by going to a higher lift cam set.
But yes, you do have to use new springs/retainers.
And there IS the possibility that there might not be enough valve relief on the piston dome. Possibly.
What about your tune after the headers/cam install?
I'm really interested in that.
Thanks.
Awesome build.
      11-08-2016, 06:18 PM   #216
crfine88
crfine88's Avatar
442
Drives: E86M
Love all the detailed photos Vanne!
Looking forward to your comments, input on the Besian stuff.
      11-15-2016, 01:25 AM   #217
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
      11-15-2016, 05:25 PM   #218
FD3S
Drives: BMW Z4M
Vane awesome work as usual. If you have some photo of the CSL intake after the mods i would be interested to see it.
      11-15-2016, 06:01 PM   #219
angelr
Awesome as always Vanne!
      11-15-2016, 10:01 PM   #220
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Looking mint Vanne, this page is full of solid updates. Your use of the two side ducts is good, has me considering oil cooler in the future.
-Matt
