      03-28-2011, 03:23 PM   #1
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Sold: Z4M SuperSprint V1 stepped headers
SOLD!
Selling my Z4M SuperSprint V1 stepped headers. $450 shipped!
These were originally installed on my car about a year and a half ago and I am replacing them with euro headers.
Here's what you need to know about these headers before you consider buying these:
1. These are catless headers
2. The V1 stepped headers were manufactured for the E46 M3 and even though SS say they will fit the Z4M, they do not fit without modification. We tried two separate sets to be sure, and both sets collided with the transmission when aligned with the engine. For this reason these were modified to align properly when fitted to a Z4M and they now fit perfectly.
3. You will see a Serive Engine Soon light as these headers cause the primary O2 sensors to miss-read. The secondary sensors also incorrectly report that they are swapped. We tried installing race cats, relocated the secondary O2s to 90 degree bungs and we worked with ESS to try and tune around it but ultimately we were not able to resolve this problem.
4. Power increase was decent - the car dynoed 298 whp with these headers, and full further SS setup including race mufflers and no cats.
5. One of the pipes is wrapped in heat shielding the help protect the engine mount in close proximity. This can be removed.
Pics:
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      03-28-2011, 03:32 PM   #2
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
wow ebay pricing for an amzing set of headers! these will sell quick
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      03-28-2011, 03:38 PM   #3
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
ess couldn't bypass the primary 02 sensors? and would the secondary 02's been ok w/ the secondary cats?
      03-28-2011, 03:39 PM   #4
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
dibs
I have cash in hand ready to pay, just need to know whats needed to run these with no check engine light
      03-28-2011, 03:42 PM   #5
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
ESS tried working around the readings but they were not sucessful.
      03-28-2011, 03:49 PM   #6
ZStig
279
Have you tried this solution?
http://www.zpost.com/forums/showthre...hlight=headers
      03-28-2011, 03:53 PM   #7
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
We did extend and relocate the rears to behind the race cats. No luck.
      03-28-2011, 03:56 PM   #8
ZStig
279
Maybe because your race cats allow more emmissions?
      03-28-2011, 04:00 PM   #9
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Possibly
      03-28-2011, 04:01 PM   #10
ZStig
279
What about getting dummy sensors? Can I do that? Thanks for your patients with all these questions
      03-28-2011, 04:07 PM   #11
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
I havent heard of anyone using dummy sensors for the secondaries. I suppose this is possible.
      03-28-2011, 04:21 PM   #12
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Did you try replacing any of the O2 sensors? Next in line after patient Roffle .
      03-28-2011, 04:23 PM   #13
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
I believe the v1's need a section 2 to match up? the stock secondary cats dont fit right?
      03-28-2011, 04:23 PM   #14
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
We did not replace any of the O2 sensors.
      03-28-2011, 04:24 PM   #15
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
I believe this is correct. I am using the SS section 2
      03-28-2011, 04:27 PM   #16
pokeybritches
2006 BMW Z4M  [8.50]
Wait, aren't the cats located in section 1? I thought "section 2" was the X pipe.
If these require the SS section 1, are you willing to part with it as well?
      03-28-2011, 04:31 PM   #17
ZStig
279
I didn't realize that this doesn't bolt up to the stock exhaust. I'm backing out. You're next in line
      03-28-2011, 04:37 PM   #18
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
I was using a full SS catless setup: SS headers + connecting pipe + x pipe + mufflers.
SS says you need either the SS connecting pipe or their SS metallic cat system however I'm sure a good fabrication shop can make anything fit.
I'm not selling the connecting pipe since we already attached the euro headers to this section.
      03-28-2011, 04:48 PM   #19
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
so to clarify to the future buyers(my understanding)...
-the v1 will not bolt up to the factory system
-you will need to do minimal fabrication to make it fit(any muffler shop)
-you will need a tune to bypass the primary 02's as long as you keep the secondary cats on.... active autowerke or ess
an amazing buy nontheless
      03-28-2011, 05:30 PM   #20
pokeybritches
2006 BMW Z4M  [8.50]
PM sent
      03-28-2011, 07:03 PM   #21
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
