06-28-2022, 01:39 PM | #1 |
Rep 6
My Fourth Z4 E85
So, still dealing with EVAP blues and can't pass emissions here in CT unless I get the light to stay OFF! My 2003 3.0 threw the EVAP small leak code from hell and after replacing the cap, front intake solenoid, rear pump and ebay canister, light tripped again. My little slingshot has now expired registration due to this uglyness and I'm getting tired. I'm looking to hear about other similar nightmares and don't tell me that I now need to remove the gas tank and I bet someone will....ugg
This is my fourth Z4 3.0 and love this car. Why would anyone desire to look else where for a fun, fast and damn good looking roadster. I drive this beast in steptronics all the time and rev her high which she appears to enjoy. Oh, and don't forget to remove the foam inserts in the intake /firewall flex pipe. I'm hoping someone can shed some light and provide next steps towards resolution. Chris in CT.... Last edited by Malibu111; 06-28-2022 at 01:44 PM.. |
06-28-2022, 03:08 PM | #2 |
Rep 1,076
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
I had a recurring issue on a M52 2.8 Z3 I had forever and its been so long I can't remember if it ever got solved. It may of been a sensor or perhaps intake boot related. Will try to dig deep in the memory.
It doesn't go away once car is fully warmed up?
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
06-30-2022, 07:06 AM | #3 |
Rep 12,565
Without obd codes hard to diagnose
wdb4716.50 |
06-30-2022, 01:41 PM | #4 |
Rep 406
If you haven't already… download INSTAD and purchase cable for it. Then read the codes (memory codes as well)…. Clear and then run car and see what active codes reappear. Diagnose those those codes using INSTAD and look at the causes/solutions recommended and go from there.
If I remember correctly there is something in the rear bumper that can cause the fault. I never had to go that far (gas cap replaced) when I had that issue, but remember that particular "device/whatever it was" as a potential cause.
Sent from my smart phone...
wdb4716.50 |
07-01-2022, 08:42 AM | #5 |
Rep 6
Still happening
Yes, code P0442 ( small leak detection)
Replaced gas cap Replaced intake purge sensor (engine bay) Replaced EVAP tank pump (rear bumper) Replaced EVAP tank with eBay purchase (rear bumper) |
07-01-2022, 02:55 PM | #6 |
10626
Rep 4,849
Go to a good mechanic.
Your system needs to be pressurised with a smoker. Much cheaper and more effective than randomly replace parts. A leak can be anywhere, might be as simple as a $1 piece of rubber hose... It's ISTA D, not INSTAD...
