05-13-2022, 09:15 PM | #1 |
Not great. Not terrible
7445
Rep 2,700
Check my gap.
I feel like this is too much gap.
How would I adjust it? Undo those bumper cover screws and push?
Current: 2024 BMW X3 M40i.
05-13-2022, 11:19 PM | #2 |
Rep 2,547
WOW, that gap look 5 times the 4mm spec. Has it ever been in an accident? Start with loosening the fasteners along the top of the bumper and seen how much movement there is.
Here's the body gap specs: |
JustinHEMI7445.00 |
05-14-2022, 05:41 AM | #3 |
Rep 2,704
Yes, too much gap.
Looking at the alignment at the corner of hood and fender at top of first pic I would say the hood is fine. Loosen the torx headed bolts on the retainer strip for the bumper cover. Leave them semi tight, then you can push the bumper cover in and it should hold it's location during alignment. You may need to set a couple of locations at a time, tighten those and then go at the rest to get the perfect gap. Of course the hood needs to be latched to make the adjustments. I even went as far as adding thin washer shims at strategic bolt locations to align the top of the bumper to the top of the hood
racerbruce3853.50 JustinHEMI7445.00 |
05-14-2022, 06:21 AM | #4 |
Rep 569
Drives: Porsche 993
I thought this was going to be something different.
JustinHEMI7445.00 ///M Power-Belgium63356.50 |
05-14-2022, 06:57 AM | #5 |
Rep 2,704
Wrong sub Murf
Murf the Surf18945.00 JustinHEMI7445.00 |
05-14-2022, 08:27 AM | #6 |
7445
Rep 2,700
Thanks all. No accident. I'll see what I can do with it. I do know that the nose emblem was replaced by a previous owner. I suspect that's where the misalignment came from.
05-14-2022, 10:22 AM | #7 |
Rep 2,547
05-14-2022, 10:44 AM | #8 |
7445
Rep 2,700
I don't know either.
05-14-2022, 10:50 AM | #9 |
7445
Rep 2,700
Checked previous owner service records. The place he took it to removed and reinstalled the bumper several times, twice for headlight issues, and they cite once for front emblem. In any case, I assume they didn't align it properly the last time they had it off.
05-14-2022, 11:20 AM | #10 | |
Rep 2,547
JustinHEMI7445.00 |
05-14-2022, 11:42 AM | #11 |
7445
Rep 2,700
Good to know if I have to do it in the future. Thank you! At least we know the likely cause of the misalignment.
pungo880.00 ///M Power-Belgium63356.50 |
05-14-2022, 04:59 PM | #12 |
7445
Rep 2,700
You guys were right (not that I doubted you), easy peasy fix. Got several mm's of movement by loosening and closing the gap. Thanks!
05-26-2022, 10:21 AM | #13 |
Rep 24,667
How are you my friend ?
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-26-2022, 10:49 AM | #14 |
Rep 569
Drives: Porsche 993
05-26-2022, 10:54 AM | #15 |
Rep 24,667
