07-19-2018, 05:25 PM | #1629 |
Rep 55
Another question on the Halo 9. Do all the steering wheel controls still work?
07-20-2018, 11:33 AM | #1630 |
Rep 199
07-24-2018, 10:05 AM | #1631 |
Rep 911
hood vent splash gaurds
Not bought, but custom made using some aluminum
Andre - 2J into a Z4 Coupe!
Azeka1285.50 |
07-24-2018, 10:55 AM | #1632 |
Rep 202
Getting ready to flush all of the fluids this weekend. Once I bed her down for the winter, I am looking to do the valve adjustment and VANOS rebuild.
2006 Z4 ///M, Interlagos Blue/Beige
07-24-2018, 08:50 PM | #1634 |
Rep 911
I did!
To be fair, they are not fully blocked off, but hot air can still escape through the openings on normal driving / car wash / trailer hauling. Once at the track, splash shields come right off with just 6 screws You can see I have quite a bit of stuff that sits right under the shields and cannot get wet. (that air filter would get completely drenched) I also don't like water tricking in there as I'm seeing rust on some body and frame pieces. No bueno.
08-01-2018, 03:33 PM | #1638 |
Rep 1,107
08-01-2018, 03:38 PM | #1639 |
Rep 461
08-07-2018, 01:47 AM | #1641 |
636
Rep 3,124
AH HA!
So I'm not the only one to have failed VT mounts! And you're correct. They are not repairable, contrary to their original statement. There's a thread here someplace on my switch to BimmerWorld and my custom heat shield.
08-07-2018, 11:51 AM | #1642 |
Rep 202
Doing a flush of all fluids for Inspection II. Changed out transmission fluid, differential oil, power steering fluid, brake fluid, and coolant. Will wait on the oil change until after I do the valve adjustment and VANOS rebuild. Also replaced the A/C belt. The Royal Purple Synchromax that I put into the transmission has made shifting smoother.
08-08-2018, 05:56 PM | #1643 |
Rep 202
Also, I built these from some 2x8 and 2x4 lumber so I could get my floor jack under the front jacking point. They worked well and were pretty inexpensive. From there I was able to get the front onto jack stands.
08-09-2018, 06:30 AM | #1644 |
Rep 912
Built myself a pair like that a while ago. Makes life much simpler.
08-09-2018, 11:22 AM | #1645 |
dances with roads
4718
Rep 4,096
I have single thickness pieces, which worked fine on other cars in the past but which I now know aren't enough for this car. Off to the lumberyard.
08-09-2018, 09:20 PM | #1646 |
Rep 431
Bimmer World solid shifter to match the Turner Motorsports solid engine & trans mounts.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
08-09-2018, 09:50 PM | #1647 |
Rep 155
Drives: M4; X4 M40i
I retro fitted cruise control on my Roadster.
08-10-2018, 08:18 AM | #1648 |
Rep 4,365
New Serpentine belt, rear shocks, rear tires, oil change, various fluid flushes. Looking to do the windshield trim here in a few weeks as well after seeing a good thread about that.
