      05-09-2012, 04:57 PM   #1
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Volk Wheel Hubcentric Rings
Just putting this here for those that have Volk wheels and might be needing hubcentric rings. I've already done some research for you folks
What you'll need are FOUR (4) 75mm --> 72.56mm rings. I'd recommend getting aluminum/metal hub rings if you do any tracking at all, as cheaper plastic ones will melt at track temps.
You can order hubcentric rings from various online vendors, but here's one to start off the thread:
https://www.1010tires.com/store/p-93...-set-of-4.aspx
Just for reference, I personally spent about $50 USD for a full set of four aluminum rings, shipped to me.
Good luck, and let me know if you have any questions. Happy motoring!
      05-09-2012, 05:45 PM   #2
3002 tii
3002 tii's Avatar
2282
Did you have to replace plastic ones or something?
Follow for latest mods
      05-09-2012, 06:14 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Some Volks come in the right hub size
      05-09-2012, 06:23 PM   #4
mfanatic325
///M-fanatic
Taiwan
193
Yup! The ones that came with my wheels upon purchase were urethane ones, which were already an upgrade from normal plastics, but they too couldn't take the heat. And I also got some PM's regarding the topic so I figured I'd post it up for the good of all that read
Oh do they now? Because I was under the impression-from some quick research-that Volk just did 75mm center bores for all BMWs, since that way it's less work on them and they have a one size fit all application. Apparently some 5-series have slightly larger hub bore than the usual 72.6mm
      05-09-2012, 06:28 PM   #5
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
E39 5-series, current gen X5s and current gen X6s (only on the front) have the oversized hubs. All others 5 bolt BMWs are the 72.6mm
      05-09-2012, 06:30 PM   #6
mfanatic325
///M-fanatic
Taiwan
193
^ There we have it folks! Goes to show that I'm not just spewing a load of BS
      05-09-2012, 06:33 PM   #7
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      05-09-2012, 06:36 PM   #8
mfanatic325
///M-fanatic
Taiwan
193
      05-09-2012, 09:44 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I'm not sure why they did it but my VR.G2 are made with 72.6
      05-09-2012, 11:02 PM   #10
3002 tii
3002 tii's Avatar
2282
Actually intgr8r and daemon are both right, yes not all BMW hubs are the same. But Volks requiring hubcentric rings doesn't really have to do with that. When Volks released wheels for BMW, I'm almost certain the fitments were not meant for the e39 so they all require hubcentric rings. But every once in a while you may come across a set of special order wheels that are already hubcentric.
One example: http://forum.e46fanatics.com/showthread.php?t=804763
      05-10-2012, 12:24 AM   #11
mfanatic325
///M-fanatic
Taiwan
193
Those hubcentric Volks must have been custom-ordered/made. Others--part of Volks' typical run batches--were bored to 75mm for one-size fits all applications (with the use of hub rings of course)
Everyone's right in here. Why are we so damned smart? Can't we be wrong for once?
      05-10-2012, 06:59 AM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The correct hub size is one of the features of the VR.G2.
With the G2 they do it for all the various model fitments.
I guess it's just a feature of this particular Volk wheel .
http://www.rayswheels.co.jp/2009/pro...-18&for=import
      05-10-2012, 10:06 AM   #13
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
OP's link not working on my work computer, will try at home. thanks
      05-10-2012, 10:38 AM   #14
3002 tii
3002 tii's Avatar
2282
As long as we're all right and you're wrong!
      05-10-2012, 10:40 AM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
      05-11-2012, 01:46 AM   #16
mfanatic325
///M-fanatic
Taiwan
193
      05-11-2012, 12:55 PM   #17
ZStig
279
Ffs they won't ship to my address in PA. WTF
      05-11-2012, 02:28 PM   #18
3002 tii
3002 tii's Avatar
2282
Will they ship to nj? If so I'll ship to you.
      05-11-2012, 03:44 PM   #19
mfanatic325
///M-fanatic
Taiwan
193
Wow, that's unfortunate Rofflz. Bad luck I suppose...
      05-11-2012, 04:39 PM   #20
ZStig
279
ok its working now, ordered. thx
      05-11-2012, 11:23 PM   #21
mfanatic325
///M-fanatic
Taiwan
193
Good to hear. I should be getting mine in another week or so (assuming they sent the rings via ground shipping).
      05-15-2012, 08:09 PM   #22
mfanatic325
///M-fanatic
Taiwan
193
I got my rings in today and surprisingly they're blue anodized
I personally don't mind, since I currently have blue lugs, and there's some blue Volk stickers on my wheels. Plus, you can't really see the hub ring once installed anyhow.
I swapped my old warped and cracked urethane-plastic rings out with these aluminum ones and went for a test drive. Found a noticeable decrease in wheel vibration and smoothness
