12-08-2021, 08:28 PM | #23 | |
Rep 973
grannyknot950.50 |
12-09-2021, 04:57 AM | #24 | |
Rep 779
Is there a way to adjust or modify the pressure in the shocks for a more compliant ride or can you recommend a different shock that would do the job?
2008 E86 M coupe
12-09-2021, 07:10 AM | #25 | |
Rep 973
Btw, they quoted me 3k |
12-09-2021, 07:22 AM | #26 |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
Tckline or ground control use Koni yellows which should be less harsh, if you can figure out how to use stock shock mounts I'd imagine that's the best you could do without going to a custom job
12-09-2021, 09:17 AM | #27 |
Rep 49
Drives: Z4MR
I believe a lot of the NVH in the front comes from the much stiffer FCAB and strut mounts. The Z4M FCAB is solid rubber vs the very soft oil filled standard bushing.
If you notice the KW V3 uses an E39 strut mount which has the entire spring and strut supported in a rubber bushing, like most other BMW models. The Z4M and other M cars use a different strut mount style which hard mounts the spring to the chassis on a wide bearing and has minimal rubber in the centre for the shock. This is obviously more durable for heavy track loads but not as comfortable as the standard BMW strut mount style. |
grannyknot950.50 |
12-09-2021, 09:26 AM | #28 | |
Rep 12,565
It’s too bad Dinan never offered springs. I ran Dinan springs on my 135is with BMW Performance shocks and that was hands down the best street performance setup I owned. Last edited by 3002 tii; 12-14-2021 at 10:06 PM.. |
grannyknot950.50 |
