Go Back   ZPOST > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      05-16-2023, 02:19 AM   #353
Tambohamilton
Drives: E91 330d
Originally Posted by Sreten View Post
Anytime! It's nice to chat about this.
Frankly, you can't compare a 4-cyl with a V10. 10 cylinder engine with more than double the power is a totally different animal and far more complex to engineering.
But Honda is more reliable than BMW, no argument there.
S65 has another big issue that S85 doesn't have, main bearings. They don't fail as often as rod bearings, but mains wear badly too and there are already more than enough cases of them falling. It's always the #1 maim bearing that fails, supposedly something with lubrication. This is what happened to project Frankfurt and when they go, the block is trash.
I guess that's my point really; for all the thought and tech that went into the s85, they forgot or failed to make it properly reliable. Honda prove that a 100hp/L high revving engine can be reliable long term, so there's no excuse. BMW's priorities just lay elsewhere I guess, which is a little bit sad. I could happily forgive it for having 2.5x as many oil leaks or something, but consumable internals just never needs to happen any more.
That said, I bet the bearing issues would be solved by a good ~5w-30 oil instead of the factory spec treacle. Remember, more oil pressure isn't better, so long as you have enough!
      05-16-2023, 08:42 AM   #354
Chihuahua
Chihuahua's Avatar
4076
Drives: E30 329iS, E65 Alpina B7
Originally Posted by Tommysalami View Post
You may want to consider resetting the EDC. In a scan tool under service/chassis/electronic damping control K, or in ISTA, select "Adjustment, shock absorber" and run it for both axles. The EDC system tracks the car's mileage and make the shocks stiffer over time to compensate for wear, making new shocks feel harsh after replacement. I installed the same B6 damptronics after 70k miles on the chassis and they were skipping and losing traction over small bumps. It was noticeably better after resetting.
From some technical documents on the E65 where I guess this system was introduced:
https://www.meeknet.co.uk/E64/09_E65...20Dynamics.pdf
From Page 20
Tolerance Adaptation
The damper force is diminished as part of the operating time function. Diminishing damper forces are compensated by current (amperage) reductions which are calculated by the tolerance control. This also individually compensates for mechanical damper wear on each axle.
And from page 23
Mechanical wear causes the dampers to weaken over the service life, therefore a running time memory adapts the damper curves towards a harder setting (over time). Faulty dampers must be replaced together (in pairs) on a single axle. After a replacement, the running time memory for the front or rear axle must be reset with the DISplus.
May also apply to your Alpina?
It shouldn't, the B7 doesn't have EDC. Alpina used Eibach lowering springs and the same Sachs dampers that BMW put on the E65/E66 sport models. There's only one damper option for the B7 unless you want to go with coilovers (blasphemy).
      05-16-2023, 06:32 PM   #355
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
anyone else curious about the e93 m3 vert that sreten mentioned in one of the recent episodes. did he buy a whole car just to take the motor for his e92? it didn’t even look crashed… but maybe i’m wrong.
      05-17-2023, 02:00 AM   #356
Tambohamilton
Drives: E91 330d
Sreten doesn't like sunroofs, so I can't see that he'd be too precious about a vert. Also useful to have a whole parts car
      05-17-2023, 02:06 AM   #357
Mani59
BMW Miniature Collector!
Drives: E38 735i SE Individual
The E93 M3 is indeed a parts car. A little more information on that in the next episode
Visit my (mainly) BMW gallery http://jetone.co.uk
Almuliman483.50
      05-18-2023, 10:04 AM   #358
Mani59
And here is Part 3 of Project Frankfurt (E92 M3).
toxik2454.50
B58 parts477.00
      05-18-2023, 11:23 AM   #359
NikMN
Drives: BMW F10 n63tu
Sweet.
      05-18-2023, 11:31 AM   #360
WrathOTM
WrathOTM's Avatar
543
Drives: BMW 128i
hey just what I was asking for
Mods to date: The list grows...
      05-18-2023, 12:30 PM   #361
WrathOTM
WrathOTM's Avatar
543
Drives: BMW 128i
Also Sreten Next time you do a tear down, tap on each piston to see if you have a "disconnecting rod".
      05-19-2023, 09:21 AM   #362
Tambohamilton
Drives: E91 330d
Pretty clear what happened there: the first main bearing spun, because s65. Owner kept driving, as it deteriorated further and further... That bearing got so loose that the nose of the crank started to flex a lot. This probably caused a lot of wear on 1 and 5 rod bearings, and destroyed the front main seal...but the owner kept driving. Eventually the front main bearing got so loose that the flex was enough to break the crank. Only then did the driver take notice. I bet it was driven for hundreds of miles, eating the front main bearing, before the crank snapped. Heat doesn't really factor in the crank failure at all, though for sure there would have been a fair bit generated. Special.
F32Fleet3571.50
M3_Legend352.00
      06-09-2023, 09:34 AM   #363
Mani59
The next episode of Project Rottweil (E39 530i Touring) is now available.
Plus a special guest appearance of the lovely E39 M5.
      06-09-2023, 11:41 AM   #364
Chihuahua
Chihuahua's Avatar
4076
Awesome, will check it out tonight.
Meant to ask earlier in this thread, going back to the B7 Sreten mentions some company in Czech Republic that does a lot of E65 stuff (it's Jarex or Yarex I think? not sure if I'm spelling that correctly). Does anyone have any info or a link to this place? I'd like to check them out (no pun intended
Also, does anyone happen to know what phone mount he's using in the E65?
M3_Legend352.00
      06-09-2023, 06:46 PM   #365
WrathOTM
WrathOTM's Avatar
543
Drives: BMW 128i
yay, something to watch over dinner!
      06-10-2023, 11:06 AM   #366
M3_Legend
M3_Legend's Avatar
Drives: BMW E90 & E91
I think this is the link it’s on http://www.falconfix.cz/?lang=en it’s on part 15 of project Chicago.
2009 E90 M3 DCT Space Grey current
2005 E53 X5 3.0 Alpine white sold
2008 E90 M3 6-speed Jerez Black sold
2008 E90 335I 6 Speed Black Sapphire M-sport sold
2006 E53 X5 Black Sapphire sold
2011 E91 Silver Automatic sold
2006 E91 Silver Automatic sold
2007 E91 Black sapphire 6 Speed Manuel current
Mani5913489.50
      06-10-2023, 12:07 PM   #367
NikMN
That M5 is perfect.
      06-10-2023, 03:16 PM   #368
Chihuahua
Chihuahua's Avatar
4076
thank you!
      06-15-2023, 10:57 AM   #369
toxik
toxik's Avatar
New video, I'm sure all the Colourlock enthusiasts will enjoy this one:
Mani5913489.50
      06-15-2023, 12:07 PM   #370
Mani59
I will absolutely be using a Colourlock specialist when I get round to restoring the leather in my E38.
      06-15-2023, 12:25 PM   #371
Chihuahua
Chihuahua's Avatar
4076
Woot! Will watch tonight. Looking forward to the Alpina factory tour and S65 content
      06-15-2023, 01:28 PM   #372
Jbrown7403
Jbrown7403's Avatar
Drives: 2016 BMW M4
Really interesting episode!
      06-16-2023, 11:59 AM   #373
swagon
swagon's Avatar
No_Country
13521
Drives: F80 6MT
I've got their stuff and they work a treat. I don't trust leather products from brands that sell anything from wheel cleaners to leather dyes
Mani5913489.50
      06-16-2023, 04:44 PM   #374
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://www.youtube.com/watch?v=t7b4mopGWGU
So Colourlock applied some sort of two-pqrt urethane coating? How will product get past the coating?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
