      06-22-2022, 11:55 PM   #1
Reborn_
Drives: 2007 BMW Z4MC
What's the Deal with the "Grooves" in Z4M Rotors
I had noticed these "grooves" in my rotors before, but never thought too much of it. I'm in the middle of replacing my original brakes with oem bmw rotors/pads and noticed something - the replacement rotors have grooves that span very little of the diameter compared to my original ones (see pics). So does anyone know what the design intent of these grooves are, and why bmw would change the design over time? My car is MY2007. More a curiosity than anything. Thanks in advance!
      06-23-2022, 12:20 AM   #2
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
If you're referring to the "grooves" in the center venting vanes, I believed it's for balancing the rotor. It's a method for them to remove materials in order to properly balance it. Each rotor should be slightly different, if you look closely.
wdb4695.50
Reborn_295.00
Coi288.50
      06-23-2022, 12:28 AM   #3
Reborn_
Ah, interesting. Yes, in the center venting area. The new ones have material removed too, just for roughly 10 degrees of the diameter. My originals are like 120 degrees. It’s a bad pic - should have snapped one of the other side that’s not on the car yet.
      06-23-2022, 12:39 AM   #4
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Our Audi's rotors have similar grooves, but runs shorter (only about 3 to 4 inches long) compared to what's currently on the Z4. I'm currently running Zimmermann front rotors on the Z4 and it has similar groove as the OE rotors that it replaced...similar to your old rotor pictured in the original post.
Reborn_295.00
      06-23-2022, 07:57 AM   #5
wdb
dances with roads
wdb's Avatar
4696
Makes sense.
Reborn_295.00
XMetal1125.00
racerbruce3849.50
      06-23-2022, 08:18 AM   #6
Reborn_
This is great, thanks guys. Since I’ve got 8 rotors, I’ll pay attention and post up how much they all differ if anyone is curious. Will take me a bit more time though - not sure when I’ll finish the job.
      06-30-2022, 09:39 AM   #7
Reborn_
Ok so wrapped the job up. Basically all 4 fronts had about a 40 degree cutout. The old rears had about a 120 degree cut out and the new ones had a 10 degree cutout. It’s probably the case that each manufacturing lot will have similar cutouts.
XMetal1125.00
      07-08-2022, 01:04 PM   #8
Rian_3385
Drives: M8
40 fronts with 40 degree each
      07-08-2022, 01:06 PM   #9
Rian_3385
Drives: M8
40 fronts for 40 degrees each
