      08-29-2021, 03:20 PM   #1
BimmerAddicted666
Drives: 03Z4, many E36
Automatic shifter knob
The leather was worn out on the automatic shifter knob on an E85 that I purchased. These knobs have at least 3 different shaft lengths across the BMW range. Searching E85 alone was producing expensive results. I figured out the interchange and was then able to find one in new condition for 20.00.
These all have the same shaft length and interchange:
1 Series 04-13 E81 E82 E87 E88
3 Series 05-11 E90 E91 E92 E93
6 Series 04-10 E63 E64
X1 Series 09-14 E84
Z4 Series 03-on E85 E89
Removal is easy. Put it in neutral, pull straight up with force. Try not to punch yourself in the face in the process. Happy shopping!
      08-29-2021, 06:25 PM   #2
Nipsey
Drives: 2007 Bmw z4 coupe
That is a great reference. Was anything else involved? I mean just pull straight up and nothing to detach beforehand such as release button.
      08-30-2021, 10:56 AM   #3
Nipsey
Plenty of how to’s online. I really hate just yanking on something like that till it lets go but that is obviously how they intended it to be replaced.
      08-30-2021, 02:31 PM   #4
rsutoratosu
Drives: Z4 3.0i
I think you need to be drive or neutral.. I forgot.. and lift up
-Roranji
      08-30-2021, 02:32 PM   #5
rsutoratosu
Drives: Z4 3.0i
Put in drive and turn off car and put parking brake on.. just to be safe.
-Roranji
      08-30-2021, 02:34 PM   #6
rsutoratosu
Drives: Z4 3.0i
You can always get this cf led one.. I have that
https://www.ebay.com/itm/383404042022
-Roranji
      08-30-2021, 06:08 PM   #7
Nipsey
That is slick Roranji, I think I will grab one. The forward top portion of mine is peeling just above the button. Not terrible but it is annoying. Thank you for the link.
      09-16-2021, 01:00 PM   #8
Huz-Z
Huz-Z's Avatar
Got pics ?
      09-23-2021, 09:43 AM   #9
rsutoratosu
Drives: Z4 3.0i
Pics arent remote loading.. not sure, see if links work
pics arent loading try this
-Roranji
      09-23-2021, 10:54 AM   #10
Huz-Z
Huz-Z's Avatar
Thanks! That looks great!
Can the install be done by just pulling the old knob and removing the shift boot?
Thanks again for the pics!!
      09-23-2021, 07:16 PM   #11
rsutoratosu
Drives: Z4 3.0i
Yes, ill take some more detail photo, so it routes the led to the shifter but you can connect the one on the base plate or have it in 2 places. I just use the one on the shifter. I plan to cf wrap the plastic base and just cover it.
-Roranji
