08-18-2021, 07:22 AM | #1 |
Rep 17
Fault code 00000E
Good morning,
Cleared all the codes in my 06 Z4 Roadster and this code came back: 00000E - Windows: Interuption pinch protection or de-normaliztion. I know the pinch protection doesn't work all the time on the passenger window and the "auto-up" doesn't work as well on this same window. Anyone else have/had this problem. Will simply replacing the switch fix this? Thanks in advance. Tim Severn, MD |
08-19-2021, 06:46 PM | #2 |
Rep 406
I have the same issue with my passenger window. I reset the auto feature fairly regularly …. Probably 3-5 times a year. I never worry about the code as it will set each time I have an issue with the auto raise…
So… it's a non issue to me as it only takes a less than a minute to reset….and replacing switch/digging into the door are simple not worth it..
Sent from my smart phone...
