      11-10-2013, 04:31 AM   #1
Bandlu
Drives: Z4M coupe
Clicking noise after installing kw v3
I recently installed kw v3's on my car and am very happy with the handling and ride
Only problem is that I'm hearing a clicking noise. It's seems to be worse when I turn the stearing wheel right for some reason. In fact I can make it click when I tug the stealing wheel to the right. I think it's coming from the frnt wheel. Im set on highest ride height with oem wheels. Anyone any ideas?
Thanks
      11-26-2013, 02:37 PM   #2
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
Your front wheels arent rubbing on the suspension, right?
      11-28-2013, 01:04 PM   #3
Bandlu
Drives: Z4M coupe
No they're not. The noise has nearly vanished without me doing anything. I ordered a set of spacers that should be arriving shortly. I'll have to wait and see what difference it makes.
      11-28-2013, 01:15 PM   #4
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6331
Common sound with kw coilovers. I have a set on my bmw e90 and it does the same occasionally. My friend with a x5m has the same issue. I think the dead coils bind sometimes and make some sounds at low speeds. My h&r coilovers on my z4m however are quiet
instagram: @ dubsesd
      11-28-2013, 01:25 PM   #5
Beedub
Kw club sport and no noise at all here ... Apart from my teeth hitting each other.....
      11-30-2013, 08:18 AM   #6
Bandlu
Drives: Z4M coupe
That's weird. I thought I had read that they should fit like oem and make no noise whatsoever.
What's also weird is how the noise reduced drastically
      11-30-2013, 12:54 PM   #7
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
What H&R coilovers do you have and is the ride a lot harsher than stock?
