      10-14-2016, 10:31 AM   #1
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Brake Rotor: Minimum Thickness
Does someone happen to know the minimum rotor thickness for original equipment rotors on an M? Also, I'm assuming it is a metric measure (but the car universe is a strange place...). I don't have a micrometer. I see some relatively inexpensive ones on Ebay. Any reason to stay away from them? If so, are there particular brands that are not too expensive that I should look for.
Thanks folks.
      10-14-2016, 10:38 AM   #2
elerner61
elerner61's Avatar
157
Answering my own question (after searching the net, but couldn't find here in our forum).
The matrix of specs is from Pelican parts but it checks out with a bunch of other threads on other forums. The picture is of the stamping on a front rotor.
I could still use some recommendations on buying a micrometer though.
[Edit] Doing some searching and it seems I will need to buy 2 micrometers since the front spec. is over 1 inch and the rear spec. is under 1 inch. Is that right? Or should I be able to find a micrometer that would be able to measure the range between 18.4 and 26.4mm? Or buy a 1" measuring block and a 1-2" micrometer?
      10-20-2016, 01:51 AM   #3
dschultz
dschultz's Avatar
26
Drives: 07 Z4MC
I use this. Accurate enough for rotors.
http://t.harborfreight.com/6-in-long...per-60248.html
      10-20-2016, 11:02 AM   #4
elerner61
elerner61's Avatar
157
Thanks! That's a nice alternative.
