      11-01-2018, 11:52 AM   #1
mimarcos
Drives: 2006 Z4MR, 2017 S3 APR1
Z4M ST40 all around - braking balance problems?
I did a little searching yesterday and today and didn't see much related to this setup specifically.
Seems like a lot of people are running ST60/ST40 for their Z4Ms, is there any drawbacks for braking balance to running ST40 all around? I got a reasonably good quote on ST40 (355x32) for all four corners, but a friend got me a little spooked that my braking balance might be off a bit.
I'm pretty sure I've seen some people run 4-pot front and rear, with the ST40s specifically, but now I'm not turning up a ton of info on searching, mostly people running ST60/40.
Also, if anyone is experienced with this, does anyone know if there's a difference in spacer requirement for OEM wheels with the ST40 vs ST60?
2006 Z4M (Emmy), 2018 WRX 50th Anniversary, and former 2013 335is Coupe, 2012 S4 (Meli), 2008 328xi (Lucy) and 2004 X3 2.5i (Scar)
      11-01-2018, 12:58 PM   #2
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
The only benefit to going with an ST60 versus an ST40 is possibly better cooling (IMO a wash if proper brake ducts are installed) and slightly longer pad life; however, ST60 pads are a little more expensive than ST40. Stoptech designs their kits to not alter brake bias even if you run a front kit with OEM rears.
Many people with E46's run ST40 on all four corners as it offers many benefits. My opinion is to go with the ST40.
1) Ability to rotate friction rings and pads
2) ST40 is a little lighter
3) ST40 pads are a little cheaper
4) 4 piston is the max you're able to run within BMW CCA Prepared Class
5) Cheaper initial cost
Z4M_GT3 just installed this exact setup and might be able to provide better details than me.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      11-01-2018, 01:36 PM   #3
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
I think you mentioned everything on point as I would haha. As far as braking feel, ST40 all around feels PERFECT. I have driven MANY cars with multiple kinds of setups, I must say 4pot 355 all around was my favorite. Stoptech or PFC are the winners for me. I got the ST40 Trophy kit (new one's fixed the pad knock back issue fot track use, so its perfect) and I am VERY pleased with them. =)
But as far as fitment with stock wheels I have nooo clue.
      11-01-2018, 02:40 PM   #4
mimarcos
How bad is the knockback on the regular ST40s?
      11-01-2018, 07:59 PM   #5
kav
Drives: Z4M
Selling mine in the classifieds if interested.
      11-01-2018, 10:43 PM   #6
dre99gsx
Drives: 1994 Toyota Supra
Good points Azeka - to add, I went a bit more aggressive in the rear with larger piston/pad area than front, and it seems the car likes a bit more bias in the rear. Stoptech does a good job of not messing with the bias to begin with, but if it came to that on your application, I don't think you would be in a rut with a bit more bias added to the rear specifically on these vehicles.
Azeka1285.50
      11-02-2018, 09:41 AM   #7
mimarcos
For a long time I've been ignored the advice given by people far more knowledgeable than myself that the OEM brakes with proper track pads are fine so I cancelled my order for the StopTechs order and am going back to OE for the next season. Should I still find things a bit lacking, I'll go for the ST brakes, knowing that the ST40 all around should be a good fit.
And kav, I noticed, you commented on my FS: RB thread
      11-02-2018, 11:03 AM   #8
kav
Drives: Z4M
The price is stellar. How could I not!
      11-02-2018, 05:42 PM   #9
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
For track use, you'll get upset... people usually add springs to prevent it. Springs are super cheap, it's just the labor that sucks..
      11-02-2018, 08:56 PM   #10
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
I'm also running Stoptech Trophy ST40 355mm front and rear. No issues. Ease of pad fitment is a big benefit as is the cost.
As for wheel fitment, I also can't comment on OEM wheels. I can verify that 17" x 9.5" Apex ARC-8 et35 wheels do fit. You need a 5mm spacer in the front to clear the spokes.
I am having issue with Hawk DTC70 pads. I'm getting some fade under really hard braking. When these wear down I plan to switch back to PFC11. The Hawks are cheaper and easier to get, but I like pads that don't fade...
      11-02-2018, 09:08 PM   #11
mimarcos
I was just reading your thread, and I should say... damn dude. That is an impressive build. I knew you had run ST40 all around, but I wasn't sure if there was a difference since, well, your car is slightly different than mine
