Go Back   ZPOST > BMW Z4 Roadster and Coupe > Downloads for Registered Members
      06-09-2009, 09:19 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
Z4 Fuse Reference card - one example.
This is one example of a Fuse Reference Card for the Z4, "GB" version with text labels rather than symbols. I am NOT certain which Z4 models/years this covers, although they all appear largely consistent.
Another example from a Z4M can be found HERE:
http://www.bimmerfest.com/forums/sho...d.php?t=363757
Fuse Reference:
Attachment 276512
      11-12-2009, 08:09 PM   #2
kurtdaniel
Drives: bmw
yeah,,nice post..very useful for beginner car electricians..hope you can post something here about oil pressure switch repair..
      03-30-2010, 05:49 PM   #3
blender
Custom User Title
blender's Avatar
Drives: black
Another factory version, presumably British.
I like #30, the "thiefproofing system"...
Attachment 364802
      03-30-2010, 07:31 PM   #4
Skelekitty
Skelekitty's Avatar
42
Drives: '07 Imola Red Z4 MCoupe
2007 M Coupe  [10.00]
Attachment 364802
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts
      03-08-2011, 05:43 PM   #5
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Bringing this back since I pulled the fuse on my headlight washer after trying to source parts to fix that "hole" of the missing cap. Fuse #40 is what I pulled. I tested out with several pulls of windshield cleaning and headlight on, the headlight washer doesn't pop-up any more... Finally..
While I was looking at the fuse box and the diagram, I realized that my #4 has a 20amp fuse half way inserted. According to the above diagram, #4 is not used. So I pulled that #4 fuse.
I crank the engine to make sure everything is in working order. Car turned over, engine started and everything seems fine. In just about 1.5 second, it dies. So I tried again. Car turns over, all is good, press the gas pedal to rev the engine, it just dies. Put the #4 fuse back in. Everything works normally.
What does this #4 fuse do?
TIA,
      03-16-2011, 11:22 AM   #6
Ron Stygar
Drives: 2006 Z4 M Coupe
Fuel pump control.
      03-16-2011, 12:37 PM   #7
Incompatible
Drives: 07 AW Z4C 3.0Si
Originally Posted by Ron Stygar View Post
Fuel pump control.
#4 is in addition to #19 and #33?
      08-01-2013, 02:34 AM   #8
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Is fuse 30 just for the alarm? (Which I want to deactivate) it won't affect anything else?
Powered by
Tags
card, fuse, fuse card, fuse chart, reference
