      12-20-2011, 05:32 PM   #23
BIMMERGUY91
Drives: 2014 335I M Sport
Alright so here are some quick pics. I will get some good ones tomorrow.
Please excuse the poor quality and how dirty my car is. In the last couple of days I have added H&R coilovers, Rogue Engineering transmission mounts, ZHP shift knob, painted mufflers, and 35% tint on the windshield. 3" C6 tips being welded on tomorrow morning
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      12-20-2011, 05:54 PM   #24
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
where did your source the c6 tips?
      12-20-2011, 06:03 PM   #25
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
What are your ground to fender measurements?
      12-20-2011, 06:39 PM   #26
BIMMERGUY91
I cant remember right now. Ill check tomorrow. RoffleWaffle I got the C6 tips from a corvetteforum.com member who lived near me. I just posted up on the forum saying I wanted to buy some stock C6 tips and he messaged me. I got the tips along with the entire factory exhaust including x pipe etc for 40 bucks and then cut the tips off and sold the rest of the exhaust to somebody for 50 bucks haha
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-20-2011, 08:55 PM   #27
ZStig
279
measure from the ground to the highest point of the wheel well opening...
      12-20-2011, 10:45 PM   #28
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Okay, these reviews are really getting me to think about these coils as an option as well. The KWs have their benefits I'm sure, but damn they're expensive. These look like they check off all the right boxes, including price.
      12-21-2011, 12:30 PM   #29
BIMMERGUY91
Yeah man I definitely recommend them
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-21-2011, 12:42 PM   #30
Finnegan
Finnegan's Avatar
Anyone happen to know the spring rates on these? I've got to do all of my research before I buy anything!
      12-21-2011, 01:30 PM   #31
BIMMERGUY91
Ill look through all my paperwork from H&R tonight and see if I can find the spring rates.
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-21-2011, 02:14 PM   #32
JPWEraser
Drives: 2016 Corvette Z06/Z07
We should get a vendor to do a group buy on them.
      12-21-2011, 02:16 PM   #33
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
These are the rates I recorded before installing the H&R set up.
Sorry, I was only able to check the first 3" of travel.
As others have noted, the ride is improved over the stock suspension, especially over ripples in the road.
I found the ride became harsher once larger swaybars and camber plates were added. But the best news is no creaks or rattles.
      12-21-2011, 02:17 PM   #34
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
the spring rates are progressive apperantly. thats probably why they feel smoother than stock under normal driving conditions and planted and firm in the corners. i have them set with no finger gaps, and they ride great.
      12-21-2011, 02:32 PM   #35
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
I'm not sure how progressive they really are since the innitial travel is used to preload the springs into the purches. The way the coils are wound the larger coils are compressed almost completely at ride height at which point the tighter wound coils take over. (almost like a tender / linear spring set up)
      12-21-2011, 02:34 PM   #36
ZStig
279
thats a really cool chart, good stuff man
      12-21-2011, 04:05 PM   #37
BIMMERGUY91
Nice chart! Dubsesd your car is so sexy man.
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-21-2011, 07:13 PM   #38
jthorst75
jthorst75's Avatar
Drives: 06 Z4 ///M Coupe
Hey BIMMERGUY91 (question for you since you recently installed these), just curious if you reused the front strut tops for the coilovers? Also how did you gauge the setting for the adjustments as in did you count the threads or did you eyeball what height you wanted or are there instructions or notches for desired height? Thanks in advance.
      12-21-2011, 07:52 PM   #39
wyatth
Drives: E90 ZCP
Read somewhere that these units are essentially H&R springs matched with (?) Bilstein Sport shocks/struts; not necessarily a bad combo at all. Any confirmation of that from the owners?
      12-21-2011, 08:40 PM   #40
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Springs are H&R, Shocks/Struts are Bilstein. Not sure if the valving is the same as the "Sport" model.
      12-23-2011, 05:58 PM   #41
BIMMERGUY91
jthorst yes I did reuse the top hats for the front. I just eyeballed them as far as adjustment and then just adjusted until i got everything at the height i wanted and everything even.
Yes they are H&R springs with Bilstein shocks/struts but I dont know what the valving is etc but obviously they are adjustable in height unlike a bilstein/h&r spring set up
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      12-23-2011, 09:48 PM   #42
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Also on H&Rs. Rear all the way down; front 1.5mm from the bottom. Ride is great; smooth yet handles well. Highly recommend them.
DSC_0873e by M detaR, on Flickr
      12-24-2011, 06:26 PM   #43
jthorst75
jthorst75's Avatar
Thanks for the info. Also the car has to be no loaded to make these adjustments, right? If so, do you do the adjustments side to side or the car fully jacked?
Also Rated M, looking good! Maybe I'll see you around town....
      12-24-2011, 09:51 PM   #44
Endless619
DHS
Endless619's Avatar
Yup, this is true.
2023 BMW M4
2016 X3
