      05-23-2011, 06:34 PM   #1
07Z4M4me
Drives: 07 Z4M Coupe
z4M rear brakes squealing under heat?
So I had my 07 M Coupe on track at Putnam Park in Indiana a few weeks ago. First time on track with it. As I've had some track experience in the past, I was able to pick it up pretty quick, and was soon getting into braking zones well.
So...after a half hour session of clear runs...still plenty of brake feel, which was great, and no grumbling sounds that some complain of. Instead, under light braking towards the end of the session, the rear brakes were yelling like crazy, thought I had a pad going bad or something.
So after I got off the track, I talked to another guy who has a z4M, who noted his stock rear brakes did the same thing, and I believe he said a fluid change solved a lot of it. Says they were just hot due to the aggressive lapping. Any thoughts on this? Plenty of pad and rotor left, BTW....
      05-24-2011, 12:01 PM   #2
jmillet
jmillet's Avatar
Drives: 2007 Z4 M Coupe
Need more info: what brake pads are you using on the track?
DSC on or off?
I run PF-01 pads on the track and they sound terrible when they cool down.
The Z4M DSC interacts with both the engine and brake management systems:
http://www.bmw.com/com/en/insights/t...y_control.html
With R-compound tires (Toyo R-888) and -3.5 degrees of camber up front I run with DSC off; in street configuration (-2.0 degrees front camber and OE Conti tires) I leave the DSC on.
Jim Millet
2007 E86 Z4 M Coupe/ZPP Premium Package/Nav System/Heated Seats/HD Radio/CDV Delete/Strong-Strut/TCK DA Coil Over Suspension/500# front; 600# rear/TCK Camber-Caster Plates
      05-24-2011, 08:52 PM   #3
07Z4M4me
Stock pads
OE Conti tires (still trying to wear the things out!)
DSC on
Stock camber
My typical process for track cars is to run them stock as can be, and then improve the components which don't appear up to the task. The tires are an easy one, but I didn't expect the rear brakes to be an issue....but good point on the DSC...
      05-25-2011, 08:29 AM   #4
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
It's the DSC.
2006 Z4MC - #LL93158
      05-25-2011, 12:53 PM   #5
07Z4M4me
^^Have you have the same problem?
The DSC is just overheating the pads?
      05-25-2011, 06:21 PM   #6
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Yup - 2 years ago at one of our local tracks we ran a shortened circuit due to a wreck early in the day taking out a guard rail and fence. The track was damp in places so I had DSC on. The shorter configuration involved a number of long sweeping turns... My rear brakes almost caught fire... During the cool down lap, loud grinding in the last two sessions where I was really pushing it . The Hack accurately pointed out the problem.
      05-25-2011, 08:47 PM   #7
07Z4M4me
Interesting. Thanks for the info. I'll have to decide if a more agressive pad makes sense, or just don't use the DSC on track...
      05-26-2011, 07:41 AM   #8
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
I'm not sure a different friction material would have made a difference in my case. The heat was intense...
      05-26-2011, 10:57 AM   #9
Shipkiller
Shipkiller's Avatar
Drives: Me
Just to be safe, I always flush about a pint of brake fluid through the brake system before each HPDE event and again after I get home from one.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
