      02-09-2008, 07:07 PM   #1
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
How to access the light switch center?
I am doing an MFSW retrofit following the sintructions in this threat (the file in the last post)
http://www.zpost.com/forums/showthread.php?t=108233
and I need to know how to acces the light switch center! Where is it? Also, where are the slip ring connectors? HELPPPP!
      12-03-2008, 11:33 PM   #2
Nostradamus
Drives: Z4 2.5si
light switch center
Hi,
As you, I need to know how to acces the light switch center, to fit a cruise control.
Have you the answer ?
Thanks
Paul
      12-04-2008, 02:19 PM   #3
Spaceman Spiff
I actually DID figure that out by accident while I was changing my dash trim to wood:
1- Pop the driver side cup holder open
2- You see a screw in the lower right corner if I am not wrong. Take that out
3- Take out the other screw that's holding the piece in at the upper left (?) corner of the air vent (under a small plastic cap that comes off easily)
4- Pull out the vent+cup holder piece
5- Now you should be able to see the left side of the trim piece between the cup holder and the steering column that sorrounds the light switch center. It's basically held in place by a clip so you should just tug/pull and maybe push a bit with a flathead screwdriver inserted between the trim piece and dash (be careful not to scratch the trim piece)
6- Once the trim comes off, you should be able to unscrew the light switch and pull it out.
This is based on what I REMEMBER from when I changed the trim. You can use this thread (it's in Italian) to get an idea (see pics in steps 1 & 6)
      12-04-2008, 03:05 PM   #4
Nostradamus
Drives: Z4 2.5si
Great !
Thank you for this information which is going to help me
Paul
      12-04-2008, 04:16 PM   #5
Spaceman Spiff
I just noticed I forgot to give u the link to the Italian thread with pics! Here it is
http://www.motortribe.it/community/f...ad.php?t=17410
