09-11-2020, 10:17 AM | #1 |
Rep 2,147
How do you tag a member with a space in their username?
Hi all,
I've been wondering this for a while, but I can't seem to find the answer. When you want to tag a user mid comment using the "@" symbol, how do you tag a user with a space in their username? Whenever I add the space, the tag ends and moves onto the next word. I feel like I should know this by now but never figured it out. Thanks in advance.
YT: ntg44
09-11-2020, 11:13 AM | #3 |
Rep 56
The short answer: You can't.
The long answer: It all depends on the forum configuration. If configured, you can use a "." or "_" or "-" in place of the space. Without an admin telling you, it's hard to figure out if it's even possible. Usernames that contains spaces would not have been allowed during creation. If there exist usernames containing a space, it most likely had been imported from a previous version or product. |
ntg442888.50 |
09-11-2020, 11:18 AM | #4 | |
Rep 2,147
YT: ntg44
09-14-2020, 01:48 AM | #5 |
Global Moderator
6381
Rep 2,309
Drives: E90 M3 6MT
A possible workaround is to manually generate the tag using BBCode.
Every username has a unique member/user ID# This ID# can be obtained via the suffix of the profile page of each individual user. Using BBCode's standard format for tagging forum users, a tag can be generated manually with the code provided that the formatting, username, and ID# is correct. In your case, ntg44 appears in BBCode as follows
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
ntg442888.50 SYT_Shadow11477.00 |
