      09-27-2019, 04:40 PM   #1
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Center vents intermittently closed on it's own
I'm starting to run into a recurring issue with the center vents closing on it's own after a few weeks. To get it to open up again, I have to change the selection knob to redirect the air to the windshield or floor and then back to "face". Has anyone ran into this issue? If so, did you find a cause? Thanks.
      09-28-2019, 10:51 AM   #2
RKM
Drives: 2005 Z4 3.0i
I have the same issue.
      11-06-2019, 12:34 PM   #3
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Did you ever found a fix or cause? Thanks.
      11-07-2019, 04:32 PM   #4
wdb
dances with roads
wdb's Avatar
4718
Does the air get redirected elsewhere?
Are you by chance turning the automatic function off/on?
      11-07-2019, 06:59 PM   #5
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
The air does not get redirected.
I don't use the AUTO function. The only thing that's running is the fan...so it is always set at 2 or 3 clicks.
      11-15-2019, 07:50 AM   #6
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
633
sounds like a actuator issue honestly. Odd thats it's just the center vents and not the sides as well.
