      05-29-2015, 10:21 AM   #1
Twixboy
Drives: '04 Z4 3.0i 6spd
Push start button
Did some Z4's come with a push start button? I just came across this image in another thread. The button doesn't look stock so maybe the owner added it aftermarket, but it was the first time I've seen one so I figure I'd ask. If anyone's wondering, the member's name is Diokaef.
      05-29-2015, 11:49 AM   #2
JCF
Drives: 07 Z4 M Coupe
That's got to be aftermarket and even with the button you would still need the key in the ignition and turned to unlock the steering column, wouldn't you?
Seems like a wasted effort to me.
      05-29-2015, 12:01 PM   #3
Twixboy
That's what I thought. I've never seen a Z4 M in person so I figured I'd ask here to see if that was an option on the M's. Many mods that are worth it to the person who did the mod aren't worth it to another person, so all I will say is I'm impressed with his effort and creativity.
      05-29-2015, 12:01 PM   #4
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Someone else did it with a writeup: http://www.zpost.com/forums/showthread.php?t=89369
      05-29-2015, 12:13 PM   #5
Twixboy
I found the guy's DIY thread here:
http://www.zpost.com/forums/showthread.php?t=430948
He installed a keypad to bypass using his key for both the doors and ignition. There's a video to show it in action. So I take back my earlier comment - I do think this mod is really cool, although I still wouldn't do it to my car. Pressing a 5 digit code then pressing the start button really isn't any easier than taking a key out of my pocket, inserting it into the ignition and then turning it.
      05-29-2015, 12:18 PM   #6
UntzUntzUntz
UntzUntzUntz's Avatar
Drives: 21 M2 Comp
low key ejecto seato
      05-29-2015, 12:53 PM   #7
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
I remember one guy who did it, and it struck me as incredibly sketchy. you still need the key immobilizer to be read by the ignition, so you either (a) need the key in the ignition, in which case the start button is totally superfluous, or (b) you need to move the ignition sensor thingy somewhere else and put the key in there.
the guy I remember doing it took the ignition switch out and had it basically loose in the glove box, with the key permanently left in it. he then back filled the hole in the steering column with a 12v socket, which I thought was hilarious, in a riced-up-civic sort of way.
      05-29-2015, 01:56 PM   #8
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
seems like a waste of time and space
SD ///M42992.00
      05-31-2015, 12:08 AM   #9
ried
ried's Avatar
Drives: F31, F80
I like the fact that our cars are the last BMWs that start with a real key. Really, the last ones. Wouldn't change that for anything!
      06-27-2019, 02:15 AM   #10
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Thank you for the comment however even if you had found the system box the guts of the key would not had help you, anyways I had made many advances since them, will post soon.
      06-27-2019, 06:33 AM   #11
Huz-Z
Huz-Z's Avatar
Nice to see that post footer back here again!
Huz-Z
      06-27-2019, 09:14 AM   #12
gmbbs
Drives: TBD
Ummm...that push-start system has been removed and smashed with a hammer.
      06-27-2019, 10:53 AM   #13
wdb
dances with roads
wdb's Avatar
4696
Gif or it didn't happen.
      06-27-2019, 01:36 PM   #14
Diokaef
Engineer
Diokaef's Avatar
Unbelievable how things evolved in 9 years or so, literary that push start don’t even need a keypad anymore or fob, just my iPhone lol, not in a Bmw tho but still. I honestly believe someone would have more luck stealing a regular z4 then the way I modified that one
      06-27-2019, 02:24 PM   #15
Jsinghzzzz
Jsinghzzzz's Avatar
Drives: Black Z4M Coupe
Originally Posted by Diokaef View Post
Unbelievable how things evolved in 9 years or so, literary that push start don't even need a keypad anymore or fob, just my iPhone lol, not in a Bmw tho but still. I honestly believe someone would have more luck stealing a regular z4 then the way I modified that one
Got a write-up somewhere, interested to see how you iterated towards the latest version.
      06-29-2019, 02:02 PM   #16
Diokaef
Engineer
Diokaef's Avatar
I’m building a new one for my truck I will post a link when I’m done
      07-29-2019, 10:31 AM   #17
gmbbs
Drives: TBD
The car would have very hard to steal the multiple times it left me stranded and wouldn't start, including for the last time on the grid of an HPDE.
While I can appreciate the time and effort that went into the execution, having 9 non-serviceable, non-testable mechanical relays encased on a brick of resin...as Clarkson would say "That's not gone well". It was nice that the factory wiring had not been altered, so taking it back to stock was not too difficult.
Que sera, sera!
      12-05-2019, 01:31 AM   #18
Diokaef
Engineer
Diokaef's Avatar
Thanks for the update, I’m not sure what version it went on the Z4, maybe 3 or 4, however with the ones I build I got a couple that are still working after maybe 8-9 years with no problems, I did however upgraded many of the components to a solid state relays and better micro processors, I wish I would remember what number the Z4 was and yes I tried to keep as oem as possible exactly in case of problems.
      12-05-2019, 01:31 AM   #19
Diokaef
Engineer
Diokaef's Avatar
Too bad I didn’t know about you, I would gladly had sent you a new one at the time
Search this Thread:
Advanced Search
