03-03-2011, 12:56 AM | #1 |
Rep 1,149
Mac is running really slow
My mac pro has been running extremely slow lately. i tried cleaning out all the cache files, temp files etc. Cleaned out my hard disk and its still slow. i've only used 350GB out of 1TB so its not the issue of the hard drive being full. Every time i try to open a program or something it makes a shit load of noise and takes forever to open. should i do a clean install of OSX or is there a better way of making it like new again?
03-03-2011, 01:15 AM | #3 | |
Fapmin
402
Rep 2,660
Also try and take off any panels that are easily removable and blow the shit out of it with a dust remover |
03-03-2011, 01:30 AM | #4 |
Rep 1,149
i think ill try the dusting thing first. i was really hoping to not have to reinstall. All these programs are gonna take forever to reinstall.. is there a program that backs up your mail and contacts and stuff?
03-03-2011, 01:33 AM | #5 | |
Fapmin
402
Rep 2,660
There should be an export contacts option. |
03-03-2011, 01:37 AM | #6 |
Rep 1,149
lol k thanks for the help.
If anyone knows about macs can you answer me this? If i copy everything in the folder Macintosh HD> Users > My Username, then paste it in the fresh install, will all my docs and stuff be there? |
03-03-2011, 04:34 AM | #7 |
Rep 158
03-03-2011, 04:57 AM | #8 |
you know he kills little girls like you
388
Rep 892
It sounds to me like you might have a lack of free physical memory and are either paging heavily or outright swapping/thrashing. Thrashing could also account for hard drive noise. The next time your system gets like that, open a terminal:
Code:
Finder->Applications->Utilities->Terminal Code:
$ export PS1="$ " $ sar -g -p 2 10 04:53:12 pgout/s 04:53:12 pgin/s pflt/s vflt/s 04:53:14 pgout/s 04:53:14 0.0 04:53:14 pgin/s pflt/s vflt/s 04:53:14 0.0 4.5 488.5 04:53:16 pgout/s 04:53:16 0.0 04:53:16 pgin/s pflt/s vflt/s 04:53:16 0.0 0.0 444.0 04:53:18 pgout/s 04:53:18 0.0 04:53:18 pgin/s pflt/s vflt/s 04:53:18 0.0 0.0 441.5 04:53:20 pgout/s 04:53:20 0.0 04:53:20 pgin/s pflt/s vflt/s 04:53:20 0.0 0.0 448.0 04:53:22 pgout/s 04:53:22 0.0 04:53:22 pgin/s pflt/s vflt/s 04:53:22 0.0 196.0 1425.5 04:53:24 pgout/s 04:53:24 0.0 04:53:24 pgin/s pflt/s vflt/s 04:53:24 0.0 0.0 442.0 04:53:26 pgout/s 04:53:26 0.0 04:53:26 pgin/s pflt/s vflt/s 04:53:26 0.0 1.5 455.5 04:53:28 pgout/s 04:53:28 0.0 04:53:28 pgin/s pflt/s vflt/s 04:53:28 0.0 0.0 444.0 04:53:30 pgout/s 04:53:30 0.0 04:53:30 pgin/s pflt/s vflt/s 04:53:30 0.0 0.5 446.0 04:53:32 pgout/s 04:53:32 0.0 04:53:32 pgin/s pflt/s vflt/s 04:53:32 0.0 194.5 1408.5 Average: pgout/s Average: 0.0 Average: pgin/s pflt/s vflt/s Average: 0.0 39.7 644.3 $ vm_stat 2 Mach Virtual Memory Statistics: (page size of 4096 bytes, cache hits 0%) free active spec inactive wire faults copy 0fill reactive pageins pageout 9420 153613 1409 72669 221214 2637706K 141590K 640327K 4852558 29648491 1308193 9516 153919 1409 72669 220896 2921 394 738 0 0 0 9290 153400 1409 72430 221770 1783 1 957 0 0 0 3119 159123 1878 72407 221815 15342 1856 4746 0 825 0 2844 159826 1878 72404 221733 2752 9 1191 0 3 0 2256 156623 1028 77000 221503 19212 1877 9165 0 846 13 2135 157187 199 78120 220961 5473 417 2605 291 17 67 2209 156644 199 78120 221503 1083 0 408 0 0 0 2411 156500 199 77838 221506 971 0 408 0 0 0 2561 157411 200 77838 220627 917 0 435 0 0 0 2394 156550 244 77826 221507 1357 0 469 0 1 0 2232 156414 136 78206 221494 3331 393 967 0 4 5 1774 156987 168 78119 221494 1709 0 986 0 45 0 1717 157533 170 78116 220949 901 0 414 0 0 0 2032 157436 175 77949 220927 1169 3 489 0 2 0 2109 156619 166 78112 221453 4448 13 3405 1761 69 516 2125 157184 187 78112 220896 2982 390 718 0 4 0 2015 157507 187 78112 220576 877 0 402 0 0 0 3437 157268 187 77317 220362 888 0 405 0 0 0 3059 157271 198 77314 220588 863 0 387 0 0 0 2767 156921 215 77176 221453 2250 0 432 0 612 0 ^C |
03-03-2011, 05:06 AM | #9 | |
388
Rep 892
03-03-2011, 05:10 AM | #10 |
388
Rep 892
It depends on if you do an archive and install or an erase and install, the former will and the latter won't. Can you even tell me why you're reinstalling?
03-03-2011, 09:16 AM | #11 |
Rep 1,149
It's hard drive noise that im hearing. And I thought a clean install would ix it thats why Im considering it. I ordered 12GBs of ram yesterday hopefully that will solve the issue. I already have 6GB in here and i thought that would be enough but apparently it isn't.
03-03-2011, 09:32 AM | #12 |
Rep 158
In my experience if the hard drive is making a mechanical sounding noise then it is on the way out. Continuous whirring is more than likely an issue with the file system and cmd+shift+u will get you to the utilities, open disk utility select your disk and verify and repair disk permissions might be a good place to start rectifying this.
If it is a bad hard drive all is not lost, one of the simplest ways of replacing a still working hard drive is to buy a new hard drive and put it into a spare slot, download carbon copy(free) and copy original drive to new drive, remove both drives and put the new drive in slot one and you are back to how you were. Radix or others might have a better solution but with my experience (selling G5 Power Mac's and other Apple parts) this is one of the quickest solutions for those not comfortable doing more indepth instructions/processes. |
03-03-2011, 10:20 AM | #13 |
Rep 1,149
A little background. About two months ago I had a big project to do and filled the hard drive to almost 90% of its capacity. I had it like that for about a week and deleted everything. Now I have 750/1000GB available. I feel like ever since I did that project it has been acting weird. Can/should I defrag it?
The reason why I don't wanna duplicate this hard drive is because if there is a system error then it will be copied into the new one. |
03-03-2011, 01:03 PM | #14 |
Rep 4,365
If your HD is on the way out like mentioned above, it probably means in the mechanical sense and you should be OK duplicating the HD for a backup.
03-03-2011, 03:41 PM | #15 |
Rep 1,149
I have a feeling it's my HD as well. I'm gonna buy a new one today and mirror my old drive onto the new one. If it works fine then problem solved, if not then.. lets just hope it works.
Even simple tasks such as surfing the web cause hard drive noise. SMART status seemed okay but that hardly detects a failing drive. |
03-03-2011, 05:36 PM | #16 |
Rep 158
Is the sound a clicking or clunking sound? If so the sooner the better on the replacement.
03-03-2011, 06:11 PM | #17 |
Rep 1,149
i have no clue how to explain the sound other than regular hard drive working sound just more often lol I have an old HDD laying around here I'm gonna try using that before I buy one
03-03-2011, 09:30 PM | #20 | |
Rep 1,149
I'm copying the drives now I'll keep you posted on what happens. If that doesn't go through I'll do a clean install on the new drive to see if that works better. I'm pretty sure it's the hard drive, I did a PRAM reboot and it was the same deal. |
03-04-2011, 03:30 AM | #21 | ||
388
Rep 892
If it's a normal hard drive noise then I'm probably right about you being low on memory. Here's how it works: Physical Memory + Swap = Virtual Memory Other than kernel memory and binaries, physical memory is primarily used for two things, application memory and file cache. File cache is simple, every time you read from a file, it's contents are cached in memory. Application memory is primarily memory allocated for the processes' "heap", using malloc(3). File cache is "backed" by the file from which the cached data was originally read. heap is backed by swap space. In the case the a system is low on memory and more memory needs to be allocated (using malloc(3) for instance), a kernel process searches for pages (4k chunks of memory) to page out to disk in order to free up more memory. Code:
$ pagesize 4096 Code:
$ ps -ef | grep [p]ager 0 41 1 0 0:07.22 ?? 0:07.22 /sbin/dynamic_pager -F /private/var/vm/swapfile The paging space (swap) in this case is located under /var/private/vm: Code:
$ ls -l /private/var/vm/ total 6291456 -rw------T 1 root wheel 2147483648 Mar 1 08:27 sleepimage -rw------- 1 root wheel 67108864 Jan 15 17:07 swapfile0 -rw------- 1 root wheel 67108864 Mar 4 03:11 swapfile1 -rw------- 1 root wheel 134217728 Mar 4 03:11 swapfile2 -rw------- 1 root wheel 268435456 Mar 4 03:11 swapfile3 -rw------- 1 root wheel 536870912 Mar 4 03:11 swapfile4 and is really nothing more than a series of files that are used as swap devices. So supposing you use all the memory on the system, then try to start a new process which in turn attempts to allocate a lot of memory which is not available, a couple of things can happen depending on the severity of the memory shortage: 1. page outs The system needs to allocate more pages of physical memory, but first needs to free some to do so. In this case the system should check to see which pages in memory have been least recently used, and then those will be paged out to allow room for the newly allocated pages. If the pages are application memory they will be paged out to swap. If the pages are file cache, then will either simply be freed, or paged out to the file from which they were read. 2. swapping In this case the system is severely short of memory and entire processes have their application memory paged out to swap. This is known as swapping. In the case that swapping happens consistently, and heavily, this is known as thrashing. Thrashing happens when your system is continuously reading and writing a large number of pages of physical memory to and from swap. The symptoms of thrashing are: 1. Increased lag starting new processes, or switching processes. 2. Heavy, unexplained hard disk activity. 3. System freezes/hangs. These sound like the symptoms you have. There are two options: 1. Use less memory. Start fewer processes at once. or 2. Buy more memory. In either case, reinstalling the system will only delay the inevitable and will be a waste of time. Fragmentation is also likely not your issue, although you could give it a try. http://support.apple.com/kb/ht1375 |
03-04-2011, 03:37 AM | #22 |
388
Rep 892
As an addendum to my previous post, again, this is all a guess based on your symptoms. It really would help if you were to cut and paste the output of the commands listed in my first post to confirm or rule out my suspicions. Also, I've tried to dumb it down a bit, but a more complete explanation of VMM on OS/X can be found here:
http://developer.apple.com/library/m...outMemory.html |
