      11-25-2010, 07:18 PM   #1
SHEEDI
Drives: 2009 335i - Sport PKG
2009 BMW 335i  [8.50]
Lubro Moly Engine Renewal Kit
I have 2003 2.5i and it has 63k, do i really need this kit? or do we all need to take care of engine using these prodcuts. Does anybody have used these products for engine?
Description for this product.
Clean your engine on the inside! Over time, your engine develops residue on the piston rings, gunk on the tips of the fuel injectors and deposits on the back of the valves. (We've seen lots of "dealer maintained" engines that were loaded with nasty build-up.) The result of all this is a gradual reduction in power, response and economy. Our engine renewal kit removes the build-up and allows your engine to perform at its best. The kit includes one container of Lubro Moly Engine Flush, one container of Lubro Moly Motor Protect, a 6-pack of Lubro Moly Jectron and a 6-pack of Lubro Moly Ventil Sauber. Using it doesn't involve anything more complicated than an oil change. Just add the Engine Flush to your engine oil, run the engine for 10 minutes then drain the oil (and the sludge!). Mix the Motor Protect with the fresh engine oil to reduce wear, improve fuel economy and lower exhaust pollutants. Then add one can of Jectron to your fuel tank the next time you fill up. The following fill-up, add a can of Ventil Sauber. Then alternate bewteen the two on a monthly basis, adding one can of Jectron in the second month, a can of Verntil sauber in the third month, etc. We recommend this as an annual program for any engine with 60,000 or more miles on it. Plus it's a great way to bring that just-purchased BMW or MINI back to baseline.
Selling it on http://www.bavauto.com/shop.asp
Please advise
      11-26-2010, 09:04 AM   #2
lstratos
Drives: Z4 3.0i
I like to know too, some people swears by it.. I read that molybdenum disulfide helps with friction and fuel efficiency but i never saw how much and at what cost..
