09-19-2019, 11:30 AM | #2 |
Rep 2,704
Will the SMG be up to the task?
09-19-2019, 12:24 PM | #3 |
10834
Rep 4,890
Internally the SMG is identical to the manual box gearwise and clutchwise.
So on that point there is no problem. However I don't know how much clutch slip the SMG uses when shifting (but it always makes sense to lift the throttle when shifting )
09-19-2019, 12:53 PM | #5 |
10834
Rep 4,890
Already installed?
For safe measure you can use the e46 330i clutch disc. Thats 240mm instead of the OEM Z4 3.0i 228mm disc.
Bmwteo0.00 |
09-19-2019, 04:06 PM | #6 | |
Rep 8
works like a charm as far as I know z4 3.0i SMG might have 240 clutch, but my car originally was a 2.5i so it had 228mm |
09-20-2019, 07:43 AM | #7 |
Rep 912
Gonna be a tough kit to find. I bought the last new one from ESS in the spring. There was a Michigan car that had the kit. You'd almost be best to find a whole car with the kit installed.
09-20-2019, 08:56 AM | #8 | |
Rep 8
At this point I'm ready to wait for as long as it takes, all other components are upgraded (BMW performance BBK from 135i, new roof fabric, repainted body, M hood and M bumpers, rest headlights and taillights, M seats, KW var3 suspension, M-factory LSD, revised SMG). Engine is the last thing that needs a proper upgrade )) |
09-23-2019, 08:10 AM | #9 |
Rep 912
As much as I love my kit...for the budge an LS swap should be in consideration and now with the explosion of technology an electric motor conversion could also be worth looking into.
