07-25-2015, 06:53 PM | #1 |
Rep 143
Speakers behind the seats
Hello all,
I just acquired a 2006 Z4M. I've only had it a week or so but I really love it. 38K miles on her. I have been poking around to see what is what and if all thing operate as intended. When I turned on the radio, I moved the balance and front/rear and found the speakers behind the seat had very little output and equally weak sound quality. I guess I expected those to Boom based on their size. Is that how they are supposed to be? Both speakers were the same so its not a blown speaker. if anything the power to the rear channel is shot?? Any advice would be appreciated. |
07-26-2015, 04:59 AM | #2 | |
Rep 525
07-26-2015, 06:51 AM | #3 |
Rep 143
07-26-2015, 07:07 AM | #4 |
Rep 218
Do you have DSP? If you do, check the equalizer and settings. The default settings are pretty meh.
Try this thread for suggestions on eq settings. A good starting point. http://www.z4-forum.com/forum/viewtopic.php?f=2&t=17407 Last edited by JCF; 07-26-2015 at 07:16 AM.. |
07-26-2015, 07:33 AM | #5 | |
Rep 143
The more I google this issue the more I find others with similar issues |
07-26-2015, 12:28 PM | #6 |
Rep 143
it seems one solution is to fade almost fully back and then use the volume to bring the volume up in the front. there seems to be plenty of power to get good volume out of the front while still faded almost fully back. Sounds pretty good
07-26-2015, 01:13 PM | #7 |
Rep 218
Keep in mind that they are subwoofers so they aren't going to be firing all the time. Now if you're a dubstep fan, sure your setup of fading to the back makes sense... But you've got 6 speakers up front and only 4 in the back (if you have the premium) so you're missing out on the speakers designed to capture the highs. Simply upping the volume is going to overwork the fronts and could result in tinny sounding highs and crackling.
That being said, if it sounds good to you, that's all that really counts. |
07-27-2015, 12:44 AM | #8 |
Rep 335
Both my subs were broken. Pull off the grill and make sure the speakers are vibrating. If they aren't, they may be blown. It appears to be common problem. It's an internal wire that gets broken.
07-28-2015, 02:42 AM | #9 |
Turd in the Punch Bowl
19
Rep 239
In both of my cars with DSP, I found that when you fade to the rear, only the small mids give any sound at all... I thought the same thing,.... that the subs were blown... I then took the grills off where I can see the subs and faded back to center... They work fine.. It's just the way these Carver subs are configured with the DSP amp and radio......
08-01-2015, 05:04 PM | #10 |
Rep 1,247
I was going to say the same thing - mine are the same. I don't think the subs are counted as "rear" by the fader, so when you fade to back only mine seem to stop too. But when I play something bassy with the fader where I keep it - I get good bass out of them.
08-29-2020, 03:19 PM | #11 |
Rep 80
My rear speaker ( on the picture) miss out on some sounds and sometimes sound awful. I thought they are blown but seem fine. What do I do? Replace them or replace the wire as suggested/ implied here?
08-29-2020, 04:10 PM | #12 | |
Rep 335
I ended up just removing them, saving the weight, and enjoying the sounds of the engine! |
08-30-2020, 12:15 PM | #14 |
Rep 5,329
might be worth checking the Amp is function properly, they do fail occasionally.....
