      09-06-2019, 10:13 AM   #1
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
Clunk noise when disengaging clutch while engine is applying torque to drivetrain
y'know the noise I'm talking about? it often happens when you're in 2nd or 1st gear, and the car is engine braking and you press the clutch pedal.
I read somewhere that this is normal, but what causes this noise?
      09-06-2019, 07:29 PM   #2
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
Not sure if links to other forums are welcome here or not.. so just copy-pasting it
"I'm with BMW of North America, LLC. The M3 is a refined version BMW's race cars. It is designed to provide optimum power and performance in a street legal package.
In order to transmit engine torque to the rear wheels instantaneously, without any time lag, the whole M3 power train was designed with maximum torsional rigidity. To achieve this maximum torsional rigidity, the flywheel mass and its damping capability has been reduced to a minimum.
As a result, during an abrupt torque transfer (e.g. 1st to 2nd gearshift at low engine speeds) the driver can receive an acoustic feedback, which can be interpreted as a "clunking or rattling" noise.
The acoustic feedback characteristic is not a symptom of a failure, and does not compromise long-term reliability of drivetrain components (clutch, transmission, differential), nor does it adversely affect performance of the vehicle.
If you have any questions, you can phone us at 800-831-1117. "
My take is that the clunking noise comes from the DMF when its springs gets compressed / decompressed suddenly.
      09-09-2019, 04:06 AM   #3
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Hmm I don't think it's normal at all. Mine never used to do it, now does it all the time. How many miles on the car. Refurbing my driveshaft due to this. Guibo, hanger and most likely culprit , the CVJ.
      09-20-2019, 03:14 PM   #4
filtercoffee
106
Drives: 2007 Z4MC
That snippet sounds a lot like sales BS. "acoustic feedback that can be interpreted as a clunking noise" lol. it is definitely a clunk.
Also I have a lightweight single mass flywheel so it's definitely not just the DMF.
      09-20-2019, 08:24 PM   #5
vt100
vt100's Avatar
126
Well.. I had a worn out DMF replaced on my previous BMW and it did improve the sound during gear switch.
But since you don't have DMF here is another (probably even more common) clunk generator
PS: and I assume you've checked axles and guibo already
      09-21-2019, 09:08 PM   #6
Sergio19
Drives: Z4MR
Could be clutch disc spline wear.
      09-22-2019, 10:09 PM   #7
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Hmm. I accidentally deleted something here??
Powered by
      09-22-2019, 11:02 PM   #8
filtercoffee
106
Drives: 2007 Z4MC
Why do you say most probably the CVJ?
      09-23-2019, 03:27 PM   #9
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Did you watch the vid vt100 posted?
      09-23-2019, 03:33 PM   #10
filtercoffee
106
Drives: 2007 Z4MC
Yeah, I am just wondering why you think that is the most likely cause of all the possibilities. I don't remember my wheel wiggling like that last time the car was on a lift - but I will try the wheel wiggle test more vigorously next time the car is on a lift and report back. Might be a while since I don't have convenient access to a lift.
      09-23-2019, 11:52 PM   #11
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Well that list is in a cheap to expensive to replace parts/labour.
Only reason I am saying CVJ, is that is because that's what mine was/is. Which sounds EXACTLY like what your describing.
      01-13-2020, 03:50 PM   #12
filtercoffee
106
Drives: 2007 Z4MC
Yep, I have the exact wiggle problem described in the video. Thanks Vanne!
