10-15-2020, 12:29 AM | #1 |
Rep 433
Z4M Parts
I have quite a few OEM Z4M Roadster parts Z4M OEM Exhaust: $200 Driver side A pillar 9/10 condition (Roadster): $20 Passenger side A pillar 7/10 (broken tab but visually perfect; Roadster): $10 OEM side M emblems $20 each OEM M Door Sills Left and Right: $100 for both. OEM radiator cover: $30 OEM S54 engine Cover: $60 Z4M Passenger side door panel in black Napa leather. $100 Center console piece $125 OEM TPS Sensors (No issues just preventatively replaced at 50K miles): $25 each OEM Exhaust camshaft sensor (no issues just replaced preventatively: $40 OEM calipers, pads (50% life aprox.), and brake lines. $350 OEM Z4M sway bars (Front ($100 and Rear $75) BMW OEM Hazard Light Switch/Door Lock ($20) Center console door (Screw is installed to hit the light switch): $20 OEM Trunk Struts (Pair): $20 OEM Hood Struts (Pair): $20 OEM Front and Rear Springs: $150 OEM Ashtray Good Condition (Does not come with the 12V socket): $100 OEM Handle Recess Trim (Part #51167158482) New as I installed a CF version instead: $90 Last edited by rsuhandy; 03-28-2021 at 07:13 PM.. |
10-15-2020, 01:12 AM | #2 |
Rep 1,130
Assuming that the E-brake handle is wrapped in OE black leather, I’ll take it!
2014 BMW X5 Sdrive35i F15
10-15-2020, 11:19 AM | #4 |
Rep 433
10-15-2020, 12:56 PM | #5 |
Backroad Warrior
64
Rep 112
Drives: Z4MR
PM sent. THanks.
10-16-2020, 10:40 AM | #6 |
Rep 1,130
Ok thank you
10-18-2020, 11:35 PM | #9 |
Rep 1,130
I’ll take the radio volume knob of it’s available
10-23-2020, 12:41 PM | #11 |
Rep 919
Drives: BMWs
Garage List 2008 E60 M5 6MT [0.00]
2019 G01 X3 sDrive30i [0.00] 2007 E86 M Coupe [0.00] 1997 E36 M3 [10.00] 2006 E53 X5 4.8is ( ... [0.00] 2006 E85 M Roadster ... [0.00] 2002 DINAN 5 (sold) [0.00] 2013 E89 Z4 sDrive3 ... [7.00] 2011 E92 M3 (sold) [0.00] 2001 E46 M3 (sold) [0.00] 2007 R56 Cooper S ( ... [0.00] 2002 996TT (sold) [10.00] 2009 E82 135i (sold) [9.00] 2006 E85 Z4 M (sold) [6.00] 2007 B7 A4 2.0T (re ... [0.00] 2003 E46 M3 (sold) [0.00] 2002 E46 325Ci (sold) [0.00] |
PM'd for center caps.
12-20-2020, 12:13 AM | #18 |
Rep 2
Hi I was wondering if you had an OEM driver side headlight housing available? Recently broke off one of the headlight bracket tabs and now have moisture in the housing. First response on the forum so still figuring out to PM. Thanks!
12-21-2020, 11:10 PM | #19 | |
Rep 433
I've also added an OEM exhaust to the list. |
12-27-2020, 08:55 PM | #21 |
Rep 1,130
Do you have pictures of the center air vent? Thank you
02-08-2021, 02:17 PM | #22 |
Rep 102
Drives: 2006 Z4MR
Center air vent still available for $50?
