09-12-2018, 03:08 PM | #1673 | ||
Rep 1,692
The B4 set is OEM replacement level which is ok, but I would like a set of B6's but who knows how long that will be until they available. Don't really need coilovers but I would like some but in reality I only drive about 4,000 miles a year if even that so not really worth the expense. Sort of stuck about which way to turn but I am patient. Something will turn up. |
09-12-2018, 03:32 PM | #1674 |
636
Rep 3,124
I think B6 is the OEM replacement for the ///M. No option for B4.
Would rather not spend the cash for coilovers for my DD, putting a kid through College. Also can't abide lowering the car. Already drags the fangs.
09-16-2018, 08:59 AM | #1675 |
Rep 199
Finally completed the upgrade of my sound system...
1) Got the MFSW controls to work with my aftermarket HU and amp with an adapter from Connects2 2) Replaced kick panel speakers with Rainbow SL-W6 3) Installed passive 2-way for door and tweeter: Audio Systems X100 BMW Evo Plus 4) Replaced carver subs with Rainbow DL-X6 5) Relocated active sub from boot to directly behind the driver seat |
09-16-2018, 10:18 AM | #1676 | |
Rep 229
Bilstein B6s: Turner Motorsport is showing a ship date of December 13th for the B6 kit. The ones I posted were advertised with about 10K miles on the clock, and I cleaned them up a bit. I feel I was lucky to find them. I'm on the fence about having them re-valved, and lowering the PSI, before installation. Both Birds in the UK, and Fat Cat Motorsports in the bay area are recommending those modifications, but the additional cost is substantial. |
09-16-2018, 11:36 AM | #1677 |
Rep 355
don't they have lifetime guarantee?
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
09-17-2018, 12:12 PM | #1679 |
Rep 355
09-17-2018, 07:28 PM | #1680 |
636
Rep 3,124
They are free from defects in material and workmanship.
They're also free from any Nitrogen they once had in them. This would be considered normal wear and tear after 4 years and 75,000 miles.
09-18-2018, 01:27 PM | #1681 | ||
Rep 1,692
In December the daytime temps here in Florida will be pleasant and then one can work on the car. |
09-26-2018, 09:12 PM | #1685 |
Rep 355
painted my strut tower braces(wish they were thicker)
09-28-2018, 09:22 AM | #1686 |
Rep 1,692
I guess I have finally figured out what to do with my suspension refresh part 1.
Went with the Vogtland Sport Suspension Kit for 2003-08 BMW E85 Z4. Vogtland N.A. stated that the drop will not be 1.2" as advertised since I have the factory Sport Suspension, and should expect a drop of approximately 3/4" which is what I liked since my car is already low. We will see how it rides after installation and a couple of hundred miles. |
09-30-2018, 06:49 PM | #1688 |
Rep 209
Drives: Z4M roadster
A new driver’s side front wheel bearing. Only 53,000 kms and no track use - wtf? Presumably due to being stored every winter.
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
09-30-2018, 08:31 PM | #1689 |
Rep 12,565
Are you running spacers or aftermarket wheels?
10-01-2018, 08:49 PM | #1690 |
Rep 209
The rims are Apex EC7s, 8.5”/9.5”, no spacers. OEM tire sizes. Well within normal tolerances I would think, particularly given the relatively undemanding road use.
10-02-2018, 02:53 PM | #1691 |
Rep 65
Drives: 07 Z4M Coupe
Bought a new oil pan gasket and OEM aerodynamics skid skirts.
10-03-2018, 01:29 AM | #1692 |
Rep 461
10-05-2018, 09:40 AM | #1693 | |
Rep 12,312
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
10-07-2018, 09:23 PM | #1694 |
Rep 12,565
Osram CBB 7000k d2s bulbs (though it’s really closer to 5000K). Will do these and spacers together next week
rsutoratosu114.00 |
