      11-17-2023, 08:22 AM   #1
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Light Dimmer Nonfunctional
Just noticed my dimmer wheel on the light switch isn't working. is this a common fault? They're not cheap as new, so wondering if buying a used one will have the same issue.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      11-17-2023, 01:56 PM   #2
JAS1169
Drives: BMW 2003 Z4
I'm not a computer person & I'm not sure if the Z4 E85 can be affected by this but, some BMW's can have a milage tamper dot caused when a new or used LCM is installed.
Please see: https://www.bing.com/videos/rivervie...F457&FORM=VIRE
You know, if it was me, I'd simply try giving the wheel area of the dimmer a good cleaning with a spray can of Electrical Contact Cleaner. It really sounds like the contacts are either gummed up or tarnished.
      11-17-2023, 10:44 PM   #3
KevinC
your average JAMF
KevinC's Avatar
Mine failed when the car was almost new back in 2007 and was replaced under warranty.
A new LCM (light switch contains the entire light control module) is big bucks - like $400 new. I'm pretty sure it doesn't need to be coded because I replaced the switch in my 2nd Z4M when I was having panel dimming issues, and it worked fine without coding.
I like the contact cleaner suggestion above. Good luck!
'21 M2 Comp
'19 Golf R
      11-20-2023, 07:34 AM   #4
spielnicht
Petrolhead
spielnicht's Avatar
440
That explains then the high cost. Will try the contact cleaner suggestion first and go from there. Thank you.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
