04-11-2020, 07:43 AM | #155 |
Rep 1,373
Finished up my install of Westersund's kit last night. In the pics below I have the hoses disconnected from the backing plate due to pulling my front dampers out of the car to send for a rebuild. Totally forgot to take a pic before I pulled them out. The hardware will eventually be replaced with better fitting stuff, unfortunately due to the corona virus I wasn't able to go the store so I had to use what was laying around the garage.
Two things about mounting the kit: 1. You need to relocate the horns if you plan on keeping them. I was able to drill a hole in the OEM bracket that is holding the duct and bolt it to that. Its tight but it fits. 2. Triming of the plastic to route the hose from the duct to the brake is pretty easy. the whole piece of plastic trim that needs to be trimmed is easily removed. Much easier to trim it out of the car then in the car. If i was to do it again I would maybe mount a flange where the hose need to go through the plastic instead of trimming the plastic. Brake cooling by Adam McGregor, on Flickr Brake cooling by Adam McGregor, on Flickr Brake cooling by Adam McGregor, on Flickr Brake cooling by Adam McGregor, on Flickr Brake cooling by Adam McGregor, on Flickr
07 Z4 M Coupe AW/IR |
04-11-2020, 09:29 AM | #156 | |
Rep 876
A duct to replace the roundel wouldn't be too much hassle to make I believe. If I don't remember incorrectly it's just a simple type of fastening on that, press it inward and less than a quarter turn. Thanks for the pictures also! Looks great. Even if it will take a long time to rust away I would consider a couple of layers of paint on the metal parts (heat resistant paint on the backing plates).
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
04-15-2020, 08:26 PM | #157 |
Rep 131
Drives: 07 Z4 M Coupe
I'm about to get my kit installed soon. Just ordered some black paint and hardware, this weekend will be fun. I'm super annoyed that my fender liners are cracked all over and I really can't salvage them and it's going to be super spendy to replace, ugh...
@F360C I like your idea of drilling holes in the OEM duct bracts to move the horn, I will likely do something similar. Might even have bonus pics of me freshening up the front bumper if I get around to it... |
04-15-2020, 09:11 PM | #158 |
Rep 170
Just about done my install, I replaced my inner fender liner with some eBay units for a non-M Z4. Worked great with this kit as in includes a cover for the vent.
https://www.ebay.com/itm/NEW-LEFT-FR...IAAOSwPjhbxDhO |
04-16-2020, 01:27 AM | #159 | |
Rep 131
04-16-2020, 09:33 AM | #160 |
Rep 876
Good to hear you're getting the kits installed, please let me know what you think.
04-19-2020, 03:52 PM | #161 |
Rep 131
Updates to my install going on over in this thread
https://www.zpost.com/forums/showthread.php?t=1712992 |
Westersund498.50 |
04-23-2020, 06:05 PM | #162 | |
Rep 175
I'm in need of getting new front fender liners and saw these non M ones. Are they better for this kit? is there any other difference between the M version liners and the standard ones aside from just the brake duct section? Would I be able to revert to stock brake ducts with these liners? THanks |
04-23-2020, 09:38 PM | #163 | |
Rep 131
I should have some updates soon, I bought a set after I saw his comment. I think they will work out fine based on what dude said. |
04-24-2020, 12:39 PM | #164 | |
Rep 170
1- uses Phillips screw to access headlights and Brake duct cover. So the stock factory brake ducts would need to be adapted to fit. 2 - Needed to trim around the under car aluminum plate near the fcab. Otherwise clean tight fit. |
05-17-2020, 03:54 PM | #166 |
Rep 626
Going to install this kit in the coming weeks. Thanks to all the contributors on here...great info! I had a couple questions for those who've attempted the install -
- What size nuts, bolts and washers are you using to mount the duct? - Is it necessary to relocate the horn? May as well replace fender liners (I bought the ebay ones listed in this thread) and also delete headlight washers. Anything else I should keep in mind for this project? Thanks! |
05-23-2020, 01:33 AM | #167 | |
Rep 876
The horn doesn't need relocating, but you have to turn it a bit and/or bend the bracket somewhat. But it does fit without a complete relocation.
bananabun169.00 Residentj3553121.50 |
05-23-2020, 07:57 AM | #168 | |
Rep 626
Thanks, André!
05-23-2020, 01:40 PM | #169 |
Rep 231
Do you have the approximate lengths of each fastener? I want to have everything ready before I dive in.
Thanks
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
05-24-2020, 04:41 AM | #170 |
Rep 876
M8's about 1", M6's 3/4" and the M4's 1/2".
06-23-2020, 01:41 AM | #171 |
Rep 876
Made a transition piece for a customer and there might be some interest here? Some brake cooling kits use these along with a metal bracket and mount them at the sway bar. This particular one is 3"/3" but can be made in whatever dimension you desire.
08-31-2020, 01:44 AM | #173 |
Rep 876
It will work just fine.
09-01-2020, 02:05 AM | #174 |
Rep 876
Updated the price because of the current exchange rate.
12-20-2020, 02:51 AM | #175 |
Rep 876
Bump!
10-07-2021, 02:18 AM | #176 |
Rep 876
We've been down for over a year and a half because of building a house, but we're now back in business! New products will be coming soon as well. Both a race version up front and cooling for the rear as well.
