04-05-2012, 11:33 PM | #45 | |
Rep 704
Drives: '08 MC
ok, good to see you can recode it. Yes, we noticed louder bass frequencies, and louder and clearer volume levels overall. I would say it adds total volume increases and it stays clear all the way up. Would be interested to see any measurable results, as measured by any type of meter instead of an ear.
04-18-2012, 03:42 PM | #46 | |
Rep 2,551
recoded
It only takes 15 seconds or so for the actual coding part, so I was switching back and forth and there is a pretty big difference in the sound. I have to copy and rename a file each time so within a minute I'm able to switch modes. Oh, and while I was in there I turned off the buzzer for key in the ignition when the door opens, which was pretty annoying when I needed to open the door. |
04-18-2012, 09:17 PM | #47 | |
Rep 704
Drives: '08 MC
Pungo - this is awesome. Well done!!!! Interesting you found the volume to be less in E85 mode than E86, I found it to be the opposite actually. in E85, it was able to be much louder - & without distortion. So, overall you'd agree about the E85 coding sounding better, and do you think its worth it?
04-18-2012, 09:32 PM | #48 | |
Rep 1,772
Drives: 2007 Z4M Coupe
04-20-2012, 10:06 PM | #49 | |
Rep 2,551
I will say that it seems to have more punch, but the jury is still out if all frequencies sound better. It seems as though it's missing something, hard to put my finger on it. I think it needs a hybrid coding using some E86 and some E85. I'll try some more experimenting. This is not my DD so I don't get much seat time in it. The next time you're in MD bring a case of beer and I'll hook you up. |
04-21-2012, 09:11 AM | #50 |
Rep 704
Drives: '08 MC
I'd agree that it's still missing something. Some midrange enhancement would be nice. As I don't have an EQ, hard for me to adjust. Regardless, your assessment of more punch and clarity to highest volume levels are the same that mheavnc and I both found, and it's a dramatic improvement as a result. I am now satisfied and pleased with the sound quality of the stock system.
Funny, because I still dont use the stereo much, I just love the sound of the s54 too much to mask it with music. The stereo is only on when I have a passenger in the car.
08-15-2012, 07:27 AM | #51 |
Rep 45
Any updates?
I specifically bought the obdII k line cable from one-stop just to recode my e86 m amp to the roadster config. I'm planning on doing it this weekend and will post up my results/experiences. |
08-17-2012, 07:59 AM | #52 | |
Rep 704
Drives: '08 MC
Def keep us posted on your progress.
08-18-2012, 07:55 AM | #53 | |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
08-20-2012, 07:46 AM | #54 |
Rep 45
Phew... As someone who knew nothing about bmw coding, this is quite a project to undertake for something so simple.
Long story short, I'm not even at the point where I can connect to the car yet. I'll keep everyone posted. |
08-20-2012, 11:26 AM | #55 |
Turd in the Punch Bowl
19
Rep 239
Always remember that if you get an amp coded to to roadster, you have to make sure that if you ever take it to a BMW dealer, they DO NOT code the amp... If they plug it in, it will ask to be coded.. If they do code it, you will be back to the way you were... They really screwed up by changing the coding from the roadster to the coupe..
I coded mine to my wife's roadster and it sounds great.. However, I can't use the DSP settings or EQ because my wife's car doesn't have Navi.. I am not complaining at all.. I remember just how bad it was before.. I can change Bass/Treble/Balance and Fade.. gtMc's car has a amp that was coded to my wife's roadster also.. His has full functionality (including DSP) due to the fact he has exactly the same system my wife has in her roadster... (Business CD / No Navi / Premium / Carver) In short, my coding process requires me to...... 1. Take the amp out of the roadster. 2. Install a Coupe amp to the roadster. 3. Make a trip to the BMW. 4. Have the amp coded. 5. Uninstall the newly coded amp. 6. Reinstall the original amp to my wife's roadster.. 7. Return Coupe amp to owner.. Would love for someone to find a better way... This process only applies to Z4 Coupes that have the premium 10 speaker system with Carver subs without Navi... However, I think this was a standard option on all coupes.. If you have Navi, you need to code to a roadster with Navi for full functionality.. Last edited by MHeavNC; 08-20-2012 at 12:35 PM.. |
08-20-2012, 12:08 PM | #56 |
Rep 45
Well, from what I've read it sounds like I can download the config from the amp and change every 'e86' to 'e85' and it should work.. I think. If it does work I believe I can upload the file and you should be able to go to an indy shop and have them code the amp. It will probably be cheaper than messing with the dealer and certainly easier as you don't have to tear the trunk apart.
I have the carver 10 speaker system, no nav. |
08-20-2012, 12:20 PM | #57 | |
19
Rep 239
Hope this works out... Coupe owners deserve better than what they have.. |
08-20-2012, 04:06 PM | #58 | |
Dark Sider
129
Rep 1,779
08-20-2012, 04:07 PM | #59 | |
Dark Sider
129
Rep 1,779
09-15-2012, 05:52 PM | #60 | |
Rep 2,551
E85 file
E86 DSP_E85.C02 FSW_PSW coded to E85.TRC.txt |
09-15-2012, 08:36 PM | #61 |
Rep 820
Drives: 2007 Z4MR silver grey
I never could understand why all the coupe owners said it was such a bad system, until I got together one day with a friend of mine here with a coupe and the same system (including nav). We jammed a CD of mine in my system, and he was blown away. Then we transferred the CD to his car and the difference was very noticeable, even after I set his EQ to my settings. It's actually a very nice sounding factory system, IMO. I added the BSW stage one mids and tweets, dynamatted the door cards and carver sub boxes, and I am very happy with the sound.................. it's not $3000 custom shop aftermarket good, but it is good enough for me, and I have had those expensive custom systems in my cars for years. Once you get the EQ dialed in, it sounds like a good high end system.................. runs out of headroom for me at about 60 miles per hour with the top down, but below that, or with the top up, it rocks.
John |
09-16-2012, 08:10 AM | #62 | ||
Rep 704
Drives: '08 MC
09-17-2012, 03:49 PM | #63 | |
Dark Sider
129
Rep 1,779
09-17-2012, 05:26 PM | #64 |
Rep 2,551
09-18-2012, 05:25 PM | #65 |
Dark Sider
129
Rep 1,779
[QUOTE=pungo]One more question. When using expert on the amp( or any small programming job) did you use a power supply or was the car battery sufficient to allow voltage during coding? I have a battery tender plus. Know that's not enough but I'm not going to be doing any heavy coding, just alarm and radio. Maybe three flash turn signals too.
09-18-2012, 10:36 PM | #66 |
Rep 2,872
Drives: Anything
I've done simple recoding without an external power supply...just have the key at the ON position.
