      07-09-2018, 08:48 AM   #1
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
What's your fav wheel cleaner?
-This includes OEM rims and aftermarket rims.
-It's ability to effectively clean to your satisfaction.
Racerbruce
      07-16-2018, 05:19 AM   #2
polar
polar's Avatar
Sweden
53
Drives: Z4MC07
Hello!
As I wax the OEM/aftermarket rims twice a year, just a gentler cleaning is needed.
To this I use Auto Finesse Citrus Power and the good thing about this is that its for insect splatters to.
For more stubborn dirt it has to be Meguiars Hot Rims.
It’s also very important to work the surface and product in an appropriate manner. For this I use the Wheel Woolies brush-kit and detailer brush. With these you can reach all the way in and makes the cleaning a real joy!
I also dry the rims with a waffle weave.
      07-18-2018, 08:55 AM   #3
racerbruce
racerbruce's Avatar
3854
Thank you polar,
This is great info -
Regards
Racerbruce
      07-24-2018, 02:56 PM   #4
RGlenn
Drives: 2007 BMW Z4M
Just used some Meguiar's Non Acid Wheel Cleaner recently and it did a great job at cleaning my wheels. Not too harsh, but really cuts into the grime. Like poster said above, a good set of tools and woolies is a must. This cleaner get's my vote and it's cheap at $20/gallon. Even at that I'm diluting 50/50 so it goes a long way.
      07-26-2018, 09:16 AM   #5
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
I've been using Flash Brown Royal for years. Non-acidic, cost efficient (diluted) and works very well but you still need to use a brush. That, plus some wax on the wheels every once in a while works well.
https://flashautodetailproducts.com/...l-tire-cleaner
https://www.autogeek.net/ezdebrfca.html
      08-22-2018, 09:15 PM   #6
Shota15
Shota15's Avatar
Drives: 07 Z4 M Coupe
P21s, Ph balanced, will not hurt finish, I have tried many different brands and this is the only cleaner that keeps my white rims on my T/A white.
